George Ressinger Fusion Club
- Bob Reite
- Real name: Bob Reite
Re: George Ressinger Fusion Club
Do the bubbles go away when you screw down the detector to reset it? If not, the detector has been damaged or the life time has expired. How long do you have to leave the detector screwed down before it stays reset? A brand new one will usually reset in 10-15 minutes. When it's about at the end of life it takes 1/2 hour to reset. After that you can't get rid of the bubbles. While you can continue to use it, keeping track of additional bubbles after each run, it will get to the point where you won't be able to count them, and the accuracy will be questionable.
Again, far too many bubbles for the time of run and the extremely low operational voltage.
