Complete Fusor Set-Up
Re: Complete Fusor Set-Up
Dan, those tubes have mica end windows.
Dan makes a good point, but the LND 512 does have a mica window and it was covered with the foil. I noted that the LND 512's small window was the reason for the small level of counting. Thus it was acceptable. A two inch pancake would have had a significantly larger count.
