This grid is made of 24 CoSm magnets, each side of the cube is a magnetic quadrupole.
Still working on pressure control, no star mode yet. The idea is that a particle beam going in and out the cube (star mode) travels in both directions through the quadrupole, which might have an effect similar to "strong focusing".
If that is true, a lower current compared to a non-magnetic grid at the same pressure and voltage might be possible.
Magnetic grid
- Real name: Jeroen Vriesman
Re: Magnetic grid
Great experiment! I would be amazed if it works as you expect, but I am always prepared to be amazed. Real thermal heating may occur. The curie point of those SmCo magnets is about double that of the best NdFeB magnets, which is a good thing in their favor. You will have to be mindful of this if your fusor is operated at higher power levels.
Re: Magnetic grid
Great experiment!
I have seen an idea that resemble yours (i attach the URL), but I've never seen the result!
http://www.enu.kz/repository/2010/AIAA-2010-6605.pdf
Good luck!
Good luck!
Re: Magnetic grid
indeed I chose CoSm for the high curie point. And I also would be amazed if it works as expected. (and even if the current is lower at the same voltage/pressure I still wouldn't know if my ideas have any relation with reality )
Because of the thermal effects I can only use a low current, I'm going to use a GP5 (30kV beam triode) tube to make a constant current source of about 200uA at 20kV (stat is still 4W), to get a stable plasma at such a low current I need a good pressure control system.
The system:
TPH330 + DUO008b pumps
A CF100 open/close valve directly on the TPH330, this will be open during bake-out, closed during operation
A bypass of the CF100 valve with a stepper-motor controlled throttle valve, controlled by an STM32F0-discovery board, getting it's analog input from the anode voltage of the GP5 current source.
A needle valve to let some gas in.
Pfeiffer-balzers full range gauge.
a "swimming pool pump" from a toy shop to circulate the cooling water of hte turbo pump.
the idea is to control the pressure directly with the voltage on the grid.
jpnms: that paper is very optimistic, I only hope to measure a somewhat higher voltage at the same current for the magnetic grid, knowing that even if that is the case, the mechanism behind it is speculative.
The system:
Re: Magnetic grid
Every idea is worth a shot if you can afford it and can follow through with some sort of result even if it is a negative one.
Too many ideas are spouted off like senseless machine gun fire and never mechanized. At least, you have already worked up your idea in some sort of hardware and are prepared to follow it out to some sort of conclusion.
Be sure to let us know where this work winds up.
- Real name: Roberto Ferrari
Re: Magnetic grid
Hi Jeroen
Nice setup!
Are you aware that some magnet alloys suffer under hydrogen exposure modifying their structure?
Hope your magnets are away of that problem!
Regards
Roberto
Nice setup!
Regards
Roberto
Re: Magnetic grid
Roberto,
hydrogenation is a NdFeB problem, CoSm doesn't have this problem.
I use nickel plated CoSm.
http://www.mceproducts.com/Knowledge_Ba ... marium.htm
Re: Magnetic grid
Great!
Good luck! We wait for your report.
Roberto
Roberto
