Hello everybody,
here is the current status of my Fusor project, on which I've been working on since summer 2014.
As a chamber, I'm using the classic 6" Wagner hemispheres approach. The chamber has a total of 6 CF-40 flanges. The forepump is a Alcatel 2010 series dual stage rotary vane pump. The oil diffusion pump is a Diffstak-100 (water cooled). As a radiator for the water cooling loop, I'm using cheap automotive heat exchangers together with a powerful fan. This has worked out very well so far.
The pressure gauge you can see on the above photo is a used Edwards APG-100 Pirani gauge. Although I did cross-calibrate it with Werner's full range gauge (it was way out of calibration when I received it), it forms the bottleneck of the current setup. As per its datasheet, you can count on somewhat accurate measurements down to about 10E-3 mbar. With the diffusion pump, I'm able to go much lower of course - but how much lower I can't say for sure.
For the first tests with "high" voltage I got this crude feedthrough-setup (it is a Champion FI21501 spark plug) working today. The seal is just an O-ring pressed against the flange -- works just fine so far.
These are the first plasma discharges I could generate today, using a small OBIT. I didn't bother making a nice grid for these first tests, but opted for the easiest to make geometry: a 'rectangular' grid.
The next steps are clearly laid out: make everything more professional! I'm thus working on a central DAQ system, that takes care of all data sources that can be found around a fusor. A central part of this system is already operational, namely the interface that lets me control the multi channel analyzer (see here for more detail)
I do have a BC-412 plastic scintillator that works well with the MCA and which I'm planning to use as a fast neutron counter. Placing the crystal in a lead shielding will (hopefully) get rid of the x-rays, leaving only 'real' hits by neutrons.
But that's still far away -- I'm by all means trying not to rush towards fusion, but rather try to avoid off-the-shelf solutions and make most things myself (e.g. the electronics).
So it may be some more time before I can report on 'first neutrons', but I'll have lots of fun in the process of getting there
Philipp
Austrian Fusor
Re: Austrian Fusor
Nice looking setup. You are serious as you have invested in a good base level system. I have entered you in the Plasma Club. All the best in finishing the effort as time and money permit.
- Werner Engel
- Real name: Werner Engel
Re: Austrian Fusor
Congratulations!
Looks very good!
Waiting for the next Pictures showing Neutrons/Second!!
BR,
Werner
Looks very good!
BR,
Werner
