The Make Design
brennanriddell
Real name: brennanriddell
The Make Design
Post by brennanriddell »
http://makezine.com/projects/make-36-bo ... ear-fusor/
This reactor project seems very doable, and is written in a very concise way. It mentions that the creator doesn't run at high enough voltages to fuse Deuterium, but were you to use the same project base as detailed in the magazine (i.e., the same chamber, and an additional step-up transistor or series thereof to get 30,40kv), could you fuse Deuterium safely?
Best regards,
-Brennan
Re: The Make Design
Absolutely not! The make article is only a crude demo fusor and would never fuse to a level the amateur could detect. The glass chamber would be destroyed. It is a simple effort to wow the folks and not a serious device at all.
brennanriddell
Re: The Make Design
Fair enough; I do believe I'll make this chamber for a mini fusor as a first timer, and to learn the basics of high vacuum, etc.
Perhaps later I will move to a stainless chamber to fuse deuterium.
Thanks again!
-Brennan
Real name: Dennis Brown
Re: The Make Design
Post by Dennis P Brown »
One main issue. The so-called vacuum gauge shown is completely useless and not worth buying or installing - a much more useful and very inexpensive Pirani gauges are available on ebay. A complete thermocouple based Pirani gauge offers good performance (for measuring between/under a torr and goes down to microns (10^-3 torr)) and is useful for testing that a two stage vacuum pump really works.
