Information on Beam-on-Target Neutron Source
inflector
Post by inflector »
Apologies if this has already been posted here. I found an interesting reference to a beam-on-target neutron source that contained some interesting ideas which might be usefully applied to advanced fusor design:
http://www.thermo.com/com/cda/resources ... 01,00.html
In particular, I thought the brief discussion of suppressor voltage was quite interesting.
- Curtis
Doug Coulter
Real name: Doug Coulter
Re: Information on Beam-on-Target Neutron Source
Post by Doug Coulter »
The suppressor in this case is to help prevent the acceleration of released electrons back into the ion source, which would burn it up (not to mention wasting input power). There's more than one way to skin that cat, the effect is also mentioned in the Phillips book I keep linking to here, though there it is done by the properties of the shapes involved.
I'll let everyone know how it works when the one I'm making now is tested.
