Micro-cyclotron
- Chris Bradley
Re: Micro-cyclotron
Did a quick simulation.
(Maxwell SV tends to over-estimate real-world situations because it is 2d and presumes this is a slice of stuff and doesn't 'loose' any field in the extra dimension.)
It is predicting 0.6T at 0.75" radius before the fields [appear to become] concave under the influence of the yoke.
Re: Micro-cyclotron
How much does a sheet of aluminium slow down when dropped between the polefaces? This trick always looks cool.
Re: Micro-cyclotron
A pretty classy little rig here, George. If this gets going, there are lots of cool possibilities. Keep us informed and in the loop. All the best.
Re: Micro-cyclotron
I'll leave the micro-cyclotron to you, but I'll likely steal your idea for the magnet frame for one or two projects.
I just got in some parts for small homopolar motor that needs a frame for the bearings and a pair of ceramic ring or rare earth pole magnets. I would need to bore holes in it for the shaft and bearings.
And I've been thinking about a similar frame to that for performing assorted MHD demos, things like generating current from a flame or, ahem, low-energy chemical impulse device legal in South Carolina but which I would never use where prohibited.
- Chris Bradley
Re: Micro-cyclotron
I like to save some of the adulation for when these "pretty builds" become experiments and turn out the goods.
We'll now be expecting to see what your experiment will be, and does, Tom (and George)!
Re: Micro-cyclotron
The magnets appeared to be glued in to the transformer core. Do I detect the subtle grey color of my favorite epoxy, J-B Weld? The stuff is remarkable.
While its high iron content is a problem in sensitive magnetometry fixtures (I learned to my dismay), in this case it would actually help.
It also has astoundingly good performance over a wide temperature range. I have used it in labs before. Typically, to remove epoxy from a fixture I chill with LN2 and give it a light whack with a hammer to knock it off. J-B Weld does not surrender to this trick, it will stay stuck even left in LN2 until the boiling stops.
- Rich Feldman
- Real name: Rich Feldman
Re: Micro-cyclotron
George Schmermund wrote:
>... When the magnet package arrived, I opened it up and saw a pair of shiny 1" thick by 2" diameter N50's separated by plastic spacers. ... It didn't take long to realize that I was actually fondling a hand grenade from which someone had already pulled the pin.
> Getting the magnets into the yoke was an experience that goes beyond imagination. ... The closest I can get to a simile is to say that trying to safely intercede between the ferocity of a pair of large N50's is like trying to clean a loaded large caliber hand gun that has a hair trigger and the hammer cocked. Take from this what you will. Somehow I can't see these magnets being available to the general public for long.
When this thread was new, George invited me to post this link:
a photographically illustrated case of serious injury from an accidental NIB magnet blow.
http://www.geekologie.com/2009/02/guy_l ... dymium.php
(Don't worry; the title in URL is a bit of an exaggeration).
On a related topic: Has anyone here bought NIB magnets on the internet, and validated the claimed energy product (e.g. 45 MGO) by making meaningful measurements? It seems really easy for ebay dealers to overrate their magnets by a grade or two, and get away with it. That seems to be the rule for laser diode modules sold to geeks who want to burn stuff. If you offer instant money back to the rare customer who complains, it's not hard to maintain 100% positive feedback.
- Chris Bradley
Re: Micro-cyclotron
This takes the discussion on the effects of skin coming into contact with metal to a whole new level!!
I also bought some whoppers for my work (60mm discs x 30mm depth) and when I got them, there was something just plain 'sinister' about them (beyond the skull-and-crossed-bones sign!!). I left them wrapped up!
I was happy for my smaller 22mm x 20mm pieces which are about the limit of what can be reasonably handled directly, and they mounted in my assembly very easily. I'll make a video of how well they behave in that scenario, next time I assemble one.
- Real name: Frank Sanns
Re: Micro-cyclotron or Just When You Thought it Was Safe to Go Back in The Water
It is interesting to see how quickly some of this technology changes. Just a couple of years ago, George and the rest of us are impressed by 2" x 1" NIB magnets. We should be as many of us grew up with standard iron magnets and had plenty of fun with them.
At the time, it was wondered if the NIB magnet above would continue to be available to the general public because of the safety risks. If you were impressed then, check out this 6" x 2" beast that is now available http://www.magnet4less.com/product_info ... ts_id=1065 .
Literally, 1.7 tons of force to separate the two disks if they were together.
6" starts to make for an interesting sized cyclotron. The problem now is building a yoke frame to support that long term. I do not think assembly of the structure would be much fun either!
You would certainly want a pair of these for $1300.00 total and then the yoke would be a snap by assembling scrap large steel sections obtained from a scrap yard. A nice tiny cycltron could be assembled with a field in the gap that would shame most wire wound, water cooled systems.
- Chris Bradley
Frank, this is exactly why I developed/'invented' the 'inside-out yoke' - it was all about practicality, and assembly was certainly one factor:
download_thread.php?site=fusor&bn=fusor ... 1231363693
The flux from the magnets is taken into the centre rather than the outside. The technique allows one to simply keep on adding magnets to the edge of the assembly to increase the flux concentrated in the centre. In this way, what amounts to 'the pole pieces' are also the yoke itself, with the additional benefit that charged particles will strike the metal yoke plates instead of the magnets themselves.
(The 24 magnets, each of 22mmOD x 20mm, give me a 0.12T field in an operating space ~130mm diameter and 40mm high. Running a copper cored circuit would take some 400 to 800W to generate that sort of field, depending on whether you're running a Helmholtz coil type arrangement, which would be very impractical in a small amateur vacuum chamber. More magnets and less space the field could be set as desired.)
I also bought a couple of 60mm x 30mm magnets some years back for my project, but am truly fearful of having a bone-crushing accident with them (I think they were something like 400kg pull rated). It was actually the box they came in that encouraged me to think twice - they are marked with a skull and crossed bones!!
They have remained in that box they came in!
- Chris Bradley
A 'snap' would very likely be the result (bones, metal, or even your pride when you end up with two magnets uselessly stuck together!) - these things are simply unbelievably difficult to manipulate. You would likely spend the same amount again, or more, on constructing a device that could mount these 6" magnets in a controlled manner to your yoke.
I have been considering buying a pair of these large magnets. Many of the requirements for a yoke are gone with the NIB magnets. Laminated core is not necessary as there is no field variations therefore no eddie currents as are present in AC or unfiltered rectified DC. The most important difference is the self yoke function of the magnet itself. The permeability of air is quite poor in electric coil magnets but with NIB it is excellent. This should reduce or eliminate the need for a high permeability yoke and leave the design open to mechanical considerations and safety.
- Chris Bradley
Frank, not sure what you mean here. Permeability of air is the permeability of air, isn't it!? I think you'll find that if you create a gap between two magnets without a yoke around them, you'll loose about a half of the possible field strength within the gap, because a half of the possible magnetisation that the magnets can do is wasted uselessly on creating a magnetic field within the air around the magnets from the flux from the reverse side of the magnets. If you put them in a yoke, it takes relatively little energy to align the yoke's magnetic domains, which means more field strength in the air-gap part of the circuit.
To avoid flux leakage from the yoke you will need a cross-section of yoke which is as big as the magnets cross-section area, reduced proportionately by the ratio of the saturation of the yoke and the surface magnetic flux of the magnets. This'd be around 1:2 for soft iron so you'll need a ~15.sq.in. cross-section yoke with these ~30sq.in. magnets.
Besides, you still have to mount and fix the magnets somehow. The easiest option might well be simply to mount them to a magnetic yoke below saturation. (If it is above saturation, the magnets may well jump off towards each other.)
A coil of wire in itself is essentially all air. Wound on a high permeability core concentrates the field. A magnet is equivalent to the wire and the core.
Frank - Just for clarification I'd like to reiterate that I used the transformer approach specifically because of the laminations. Of course it would have been easier to build the yoke out of some soft iron bars that could be machined to size and bolted together, but that would have required that I use my machine shop instead of just the work bench out on the back porch.
The plan was to demonstrate that the project could be done with only a hammer, chisel, file, and bench vise. The transformer was easy to disassemble and separate into just the laminations. The center leg of each "E" shaped lamination was simple to remove using a wood chisel. When reassembled it was an easy task to file the center of the yoke flat.
In my eternal state of naiveté and self delusion I thought the demo would bring at least some folks to the realization that what appears to be an overwhelming project was really quite simple to achieve even without machine tools. Soon others would follow suit. Silly me!
Getting large magnets into the yoke (any yoke) is another matter....
I have easily mounted high flux NIB magnets in a surrounding yoke (double E core) with the central machined out E legs being the gap and magnet area. With two facing magnets it is easy beyond belief at most any size or field strength.
1. Know what your desired working gap is. Let's us 1" in our example.
2. Know the thickness of each magnet in the two magnet gap. Let us say 1.5" each
3. Know the distance between the yoke ends and the diameter of the magnets. Let us say the magnets are 3" in diameter and the width of the entire yoke opening is 6"
The ideal cutout of the central E region is thus 4"
get a large piece of 7/8" thick plywood that will slide through the E iron and the entire yoke. This would be a piece about 16"X5-7/8"
Determine the polarity of the magnets and mark them.
Place one magnet under the large piece of wood centered under the wood about 6" from one end of its 16" length and clamp this fixture to a table top. On top of this wood, place a small piece of aluminum flashing over the center region of the lower magnet.
Now place the second magnet on a 1/4" piece of plywood with the pole face downward on it opposite of the one under the clamped piece.
Now, carefully, holding this 1/4" sheet high over the clamped piece lower it rapidly towards the magnet under the thick sheet. Let the sheet go the instant you feel any force of pull and it will drop into place almost in line with the other magnet.
The slick aluminum sheet will allow you to slowly work out the 1/4" plywood allowing the magnet to come into direct contact with the 7/8" plywood sheet through the aluminum sheet.
Now carefully pull, push and tug the magnets into near perfect alignment with the 7/8" sheet separating them. (make sure that they are centered within the 5-7/8 width)
NOTE*** In cases of large diameter magnets of extreme field strength, two larger semi-circles of 1/2" thick plywood may have to be bolted with brass hardware to cover half of each magnet's pole face on the long side of the 7/8" board. This keeps the magnets from flipping up against the e-irons as they are inserted in the gap.
Slowly push the 7/8" sheet with magnets into the 4" E iron gap. At some point, the two magnets will flux link through the yoke and they will attach to their respect E iron sections in the gap, perhaps even yanking the board in it as well.
Now, with the yoke fixed in a vise or fixture, push each magnet fully onto its pole face. I have done this about 3 times in the past and it works great with no crushed fingers or heavy machinery involved. A wood board and a brass mallet can be used to coax the magnets to center with relative ease. The other magnet below may or may not follow. I prefer to ease them on to center alternately and slowly. All the time the 7/8" board is mostly now free to move, but keep it fully centered and in place until both magnets are pushed to be centered on their respective pole faces on the E iron, gap, yoke sections.
The 7/8" safety board can now be removed. They will now never connect together again provided no magnetic material is ever placed in the gap. (This is critical!!!) Once this is assembled never, ever place a screwdriver or other high permeability magnetic material in the gap for demonstration or test.
Now a good gauss meter and probe can be used to measure the field.
While each case is different, any wise person can adapt this procedure to fit their particular case.
Re: Micro-cyclotron
Now that Richard has made the magnet/yoke assembly hazard seem to be a non-issue, I thought I'd rekindle the activity of making a micro-cyclotron chamber and Dee's as described in another post: download_thread.php?site=fusor&bn=fusor ... 1274837101
This construction project was also accomplished without having to use any machine tools. I keep hoping that someone will out pace me in an effort to get a micro-cyclotron up and running. This uC device could still be a potentially good neutron generator.
Re: Micro-cyclotron
Hey All,
If you are interested, here is a link to a detailed youtube video tour of our 1.2 MeV proton Cyclotron. It is kind of long, and we are not winning any awards for our acting skills, however it does cover all subsystems and operation.
http://www.youtube.com/watch?v=G2N-k5jz8bs
If you are building a cyclotron you might find it interesting.
Enjoy !
Enjoy !
