New NEC Accelerator @ work
Post by John Futter » Thu Jan 28, 2010 4:17 am
We are presently installing a brand new 0.5MeV Tandem accelerator @ work in a very small space.
Few Factoids
Analysing magent 7 tonnes
Will be used for C14, Al, and Be dating work
Insulated with SF6 @80psi
Terminal to ground about 1 foot (three rings each end of terminal)
I will add pics of the other bits when they get installed including the very cute electrostatic analyser
some of the bits.jpg (344.35 KiB) Viewed 3091 times
7ton magnet half.jpg (302.43 KiB) Viewed 3091 times
controll desk.jpg (320.86 KiB) Viewed 3091 times
closeup pelletron.jpg (357.29 KiB) Viewed 3091 times
pellertron going together.jpg (350.32 KiB) Viewed 3091 times
Dustinit
Re: New NEC Accelerator @ work
Post by Dustinit » Thu Jan 28, 2010 5:30 am
looks a bit like the back end of a crt.
Neat .
Post by Steven Sesselmann » Thu Jan 28, 2010 6:53 am
John,
Eye candy, I can't begin to imagine what it all costs..
Doug Coulter
Real name: Doug Coulter
Post by Doug Coulter » Thu Jan 28, 2010 6:36 pm
Eye candy indeed! Thanks for that. Of course it looks like a CRT, because it does the same job, create and focus a beam of charged particles. Some constants for that are a little different due to differing e/m ratios, but all the ideas are the same. And yes, I'm sure that like a yacht, if you have to ask the price, you can't afford it. It's a hole in the water you attempt to fill with cash! At that, I suspect that the salaries (or actually the net cost of the people to the outfit, which is far higher in my experience) is even larger in a pretty short time period. Nice stack of pumps too!
Post by Chris Bradley » Fri Jan 29, 2010 7:42 am
I saw one of those on ebay recently. "Tandem accelerator, with bending magnets - buyer collects. Unused stock. Archaeology dating, etc..". It went for $250.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0040680110
lutzhoffman
Post by lutzhoffman » Fri Jan 29, 2010 7:48 am
Very Nice!!!
Thanks for taking the time to post the pictures, much appreciated. Its nice to be able to see state of the art technology in visual form. Is the charging system a pelletron chain? For this voltage level another method like a VM, or HF capacitive system would be more easy which now has me doubting my pelletron chain theory. Does it use a gas stripper canal, or carbon foil?
Boy this thing has a serious bank of heat exchangers at one end, so something in it must be making a lot of heat. You could almost buy a house with the vacuum pump assortment in the first picture, it must be like Christmas to be able to use new equipment like this, I can even imagine the new equipment smell, just like a new car.
Thanks.....
Post by John Futter » Fri Jan 29, 2010 7:51 am
pity
might of saved a few million $
Post by John Futter » Fri Jan 29, 2010 7:54 am
Yes its pelletron
yes it uses a gas stripper two turbos back to back differentially pumping the gas canal
more pics soon
Post by Chris Bradley » Fri Jan 29, 2010 7:55 am
Just kidding, John... just my sarcastic Brit wit [or lack, thereof].
Lovely bit of kit. We look forward to seeing it ticking. What's the bending B field strength that yoke can get up to?
Post by John Futter » Fri Jan 29, 2010 8:05 am
No idea
but they drooled over our 2 tesla units on our implanters
