The device that I built
Re: The device that I built
Post by Richard Hull » Thu Dec 31, 2009 7:49 pm
And, the bleat goes on...and on
Doug Coulter
Real name: Doug Coulter
Post by Doug Coulter » Thu Dec 31, 2009 8:39 pm
Time to stop feeding this troll.
Chris64Strev
Post by Chris64Strev » Fri Jan 01, 2010 6:24 pm
Chris64Strev wrote:
> I did another experiment today. Here I used a Pyrex test tube containing hydrogen at a pressure of 3 Tor. The reactor was excited with 100 Watt RF at 3.7 MHz. It settled down quickly and by tuning the reactor I found that the reverse power could not be reduced to below 2 Watt. I surmise that this power in being generated in the gas by fusion of protons.
> The radiation level was only slightly above background. Here is my video of the run.
> http://www.youtube.com/watch?v=UzT4QA6ymLU
> This second video shows the background after the exciter was turned off.
> http://www.youtube.com/watch?v=BJFa7qcujXA
This result only implies a mismach. This could be due to power being generated in the plasma or just a mismatch.
Chris64Strev
Post by Chris64Strev » Fri Jan 01, 2010 7:06 pm
I do not like being called a troll, after all the Fusor itself does not do very much, as I try to be a serious experimentor.
I do not know enough theory to do an analysis so I rely on my experiments. I am trying to demonstrate the evolution of electrical power from the device. I do have a theory but I find it difficult to communicate as I lack the ability to turn my thoughts into words and mathematics.
Theory means nothing without experiments.
It is my opinion that experiments are above theory. The process of science starts with an observation then we have make a theory which starts in one man's mind and then we try an experiment to verify the hunch. This is slowly refined until something useful appears or the line reaches the buffers and we have to leave the train.
My original observation was when I was a child of about 6 playing on the floor with a child's shocking coil (this was a coil with an interuptor driven by a 4.5 volt battery that generated voltages high enough to give an electric shock) and a spectral tube that was either hydrogen or deuterium filled. In my random childish playing I put the tube inside the coil instead on attaching the electrodes and I found that the buzzing continued long after the battery was disconnected. This was purely by chance.
At present I am merely trying to repeat this chance observation.
I thought that the power to run this came from fusion many years later when I heard about the "hydrogen" bomb. (I now know that this does not run on hydrogen).
My limited recall from memory from the time I was about ten was that my Uncle Arthur had made a working engine that ran on reduced pressure atmospheric air. And wanted to market this new source of power. But he was imprisoned because the british authorities thought he had a tame poltergiest in the tube and given a frontal leucotomy. He never did anything like that again but worked as a postal clerk until he retired and lived as his sisters sex slave. He lost his girl friend to his brother because his mind had gone.
I would like to try the original experiment again but that design "tesla coil" is no longer made. I have ordered a deuterium spectral tube for about ten dollars so I could try that in my coil.
There is a nasty history here as mum was also lucotomised at about 94 in connection with this case in order to silence her and I was also treated to get rid of me but my brain regerated.
When I was at RSRS (UK) we made one which started up but I cannot recall the details for the same reason of medical intervention.
I have enough recollection to say that British Warships have similar fusion engines as their power source.
I am bound by the Official Secrets Act but under the thirty year rule I can talk as it may help the global energy crisis and global warming.
The effect was originally descibed by tesla and used by the Nazis to start off with but the British smashed all the technologists and destroyed the knowlege.
It is a British secret that this "tesla engine" worked.
The British did not want it as it would destabilise their ecomony with the rest of the world.
My friends made a working commercial one but after we sought permission to produce it for sale this was not granted as there is no way that money can be made from it. It is classified as too dangerous for commercial use. This ran on hydrogen. They were all down for execution by lobotomy.
As you know deuterium fusion generates neutrons so I will not try to run it here in my tiny upstairs back bedroom.
I fear a knock on the door at 9:30 am when they may come to take me away once again.
I was shot by the police a few months ago but the round bounced off something in my coat and I did not die. They may come again, it was just two that time the next time it was six. I'm surprised they let me out(!).
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Fri Jan 01, 2010 8:01 pm
Nazi Tesla fusion engines...state secrets protected by lobotomy..."tame poltergeists" and sexual slavery...
Banter like this thoroughly impeaches any vestige of credibility you may have had, preemptively rendering further contributions from you on fusor.net pointless! Maybe there's an audience for you on Art Bell's late-night radio show. There is no reason to hear from you again here though. Resurrecting this thread again will be a sign of poor faith and purely self-serving motives, and should be sufficient grounds for deleting your account. Move along...
Carl Willis
TEL: +1-505-412-3277
Quantum
Post by Quantum » Fri Jan 01, 2010 8:27 pm
He IS experimenting, though, Carl, which seems to be more than you've done in a long time.
While peoples personal circumstances shouldn't preclude them from posting here, I agree with you that it is not relevant.
While I saw no evidence of fusion power when I was working at the site where Rolls Royce build fission reactors for the Royal Navy, and I don't understand the experiment Chris Strevens is attempting, I wish he would provide more details of his setup, so that we may offer some 'constructive criticism'.
Carl Willis
Post by Carl Willis » Fri Jan 01, 2010 8:44 pm
P'shaw.
Since when have you been a reliable arbiter of what other people are doing or have done? I mean, do you have a leg to stand on here? Your own statements on record show that you have no understanding whatsoever of what I do. Need a reminder of that?
God, this forum has gone to hell in a freaking handbasket over the last year.
Carl Willis
Quantum
Post by Quantum » Fri Jan 01, 2010 8:55 pm
Carl, I don't want to get dragged into another 'mud slinging' contest, but what exactly do you do?
Carl Willis
Post by Carl Willis » Fri Jan 01, 2010 9:10 pm
Dragged? Ash, my boy, you veritably dove into this one by accusing me of not doing experiments "in a long time!" If you're out to point a finger at someone for slinging mud, find a mirror.
You joined this forum with much fanfare and bloviation half a year ago. Since which time your experimental record has been identically NIL. That's not a problem; we have lots of lurkers and occasional contributors. What is a problem is that your record of noisemaking in that same time period has been the most prolific of any contributor over the past decade of this board's existence, and furthermore, you somehow think you can call out others for not doing experiments.
Find a mirror.
Jeazus!
Carl Willis
Chris64Strev
Post by Chris64Strev » Fri Jan 01, 2010 9:22 pm
I won't mention it again but that is what happened, it is all around me. The shrinks visit every four hours or so.... They say they want to "cut the delusions out of my head". It is murder actually.
I just repeated the experiment with the tube containing hydrogen at 10^-4 Tor and as the gas heated up the radiated power increased as did the VSWR. I found I could tune the reactor so the reverse power went to zero but the radiated power meter read the same.
I won't be satisfied until the unit self oscillates with the exciter switched off. That is the result I am looking for.
This might happen with deuterium as its ignition temperature is much lower than hydrogen.
Don't be surpsised if I go silent. The shrinks will have got me.
Please do not be such bad sports as to delete my account...
Chris.
