If I might be so bold as to wrap this one up with a conclusion, then, the maths shows that the original article is wrong. There *will* be a slower divergence of two ions racing through empty space than might be expected classically, if they were in a stationary frame
But this is only because (as Carl's mathematical disposition demonstrated) there is both a Lorentz contraction of space and also a frame modification to the electrostatic force observed in an alternative frame. There is *not* a frame-dependent magnetic component as inferred in the article. This is only true of conduction *through a conductor*, which an individual projectile particle is not.
Magnetism...a relativisticeffect?
- Chris Bradley
Re: Magnetism...a relativistic effect?
Carl,
Never give up on your recriminations. You have the knowledge, distribute it! Besides I am getting older and every forum needs some gravity boots and an official, certified, (or certifiable), naysayer.
You will need to pack on a few more decades before you can become half the curmudgeon that I am, but work at it, hone it and don't let stuff slip by that can be picked over. Continue to help keep us honest, right and on track.
It is all part of the verve, humor, and science that blends to make a fine wine of this place.
Ricahrd Hull
Ricahrd Hull
