A compact DIY cyclotron package solution.
Post by Chris Bradley » Wed Jan 07, 2009 9:28 pm
I was playing around with magnet arrangements and the following configuration occurred to me:
Usually cyclotrons are designed with one magnet with its S facing towards the dee chamber and another with its N facing, thus forming the required magnetic field across the gap. You'll need a big yoke to bend the whole field around so as to maximise the field (just as Doug C. showed us his work the other day).
In the device I'm struggling to build, my ions may come out of the magnetic field in this configuration but I want to recycle them back in, so I can't tolerate field irregularities past the convex 'edge' of the field.
It dawned on me that the yoke could actually be 'inverted' with respect to the magnets so that the whole of the yoke takes on the flux of the outer magnets and focuses it into the centre of the dees.
This can be done by putting the magnets around the OUTSIDE of the device rather across the centre, and the 'yoke' can now be used to carry the flux into the centre.
With respect to a cyclotron, it would work as in the following images I've prepared to explain this (no hope with words!!).
So now there is a continuous magnetic field that stays oriented in the same direction all the way out to the edge of the field but then doesn't invert yet further out (if compared with a normal poleface-to-poleface arrangement).
The result is a highly compact arrangement whose magnetic yoke can double up as the dees of the cyclotron!!
So that would be it! The dees carry the magnetic flux! There is no leakage through the gap of the dees at all, and little loss to the outside circuit. You could even seal the whole thing up along the gap with a dielectric seat that can hold a vacuum such that the dees a) provide the e-field, b) carry the flux, c) doesn't invert beyond the shoulder of the field AND d) forms the vacuum vessel aswell.
If you don't want to use permanent magnets, no worries, you can replace the magnets as I've shown them with electromagnets. If you vacuum-seal those 'shields' against the dees and seal the whole thing, now the electromagnets are on the outside (air or water cooled) but the flux is actually taken into the vacuum volume by the vacuum container itself.
I think that's pretty neat as it solves 4 packaging problems simultaneously! Has this configuration ever been used before? Will it work!?
best regards,
Chris MB.
Carl Willis
Real name: Carl Willis
Re: A compact DIY cyclotron package solution.
Post by Carl Willis » Wed Jan 07, 2009 11:20 pm
Hi Chris,
I like the new approach suggested here. My gut tells me that it's unlikely to be appropriate for the high and uniform fields needed for most cyclotron projects even with modern NdFeB magnets, but it could readily be applied to very low-energy cyclotrons or to the design of microtrons (for electron acceleration).
This is an idea well worth carrying to the next level to see what it is capable of.
Some possible design challenges:
-A coating is needed on the dees that is a good RF conductor--copper, gold, etc rather than just magnet iron. They are the capacitor plates in a very high-Q, high power circuit, so lots of current can flow on them.
-Cooling of the dees to protect the magnets. Nd magnets can't exceed ~100C or they're shot. This design probably requires somewhat large dees (to handle a number of magnets and develop uniform flux in the acceleration gap), necessitating larger RF power for a given dee voltage than otherwise might be called for. So it will be important to consider the cooling needs and make sure the magnets are especially well cooled.
-Force between the dees. Assembly technique. As magnets are added, this can turn into a grenade. It has to be mechanically braced well enough that this does not happen.
Good idea.
Carl Willis
TEL: +1-505-412-3277
Todd Massure
Real name: Todd Massure
Post by Todd Massure » Wed Jan 07, 2009 11:37 pm
Hi Chris,
Interesting idea, but my first thought is that the flux would tend to reside almost completely in the circuit set up by magnets and soft iron and wouldn't be forced to jump across the chamber like it does in the figure 8 yolk design with a gap.
I tend to think of the gap in the magnetic circuit like a spark gap in an electrical circuit. Your computer model seems to show flux in the chamber area though, so I'll study it some more.
Thanks for sharing.
Todd
Todd Massure
Post by Todd Massure » Wed Jan 07, 2009 11:53 pm
Oh, ok, I get it now. Yeah, seems like it should work.
I've personally abandoned the idea of using the rare earth magnets, just because the cost doesn't seem to work out, oh and they seem hard to work with, oh and with large ones or an assembly of a bunch of them they kind of, ...ok really, scare me.
I might consider using a similar layout with electromagents. It would be nice to be able to find a bunch of off the shelf solenoids or something instead of getting coils custom wound. Plus all the extra surface area on the magnet coils would probably really help with cooling. Plus, who needs a couple of tons of yolk iron to deal with.
Great idea.
Todd
Post by Chris Bradley » Thu Jan 08, 2009 12:19 am
Thanks for the positive feedback.
My build differs from this actual arrangement, but this comment may still apply. Either way, a worth while comment if it gets taken on as a cyclotron design, as I've posted.
EH grades run to 200C, and I think there are higher grades now even. But that's by-and-by. The point is that the surfaces could now be external if the dees also form the chamber, so could be cooled externally which is a much easier challenge.
>This design probably requires somewhat large dees (to handle a number of magnets and >develop uniform flux in the acceleration gap)
I guess you might be right, though these 2D simulations (Maxwell SV/2D) didn't show up anything noteworth other than uniform fields. I anticipate some pole shape tuning could mostly overcome that concern if it presents itself.
I've always been worried about this (ref my other post on monster neos). I bought a large quantity of smaller magnets and have realised they are no so scary as I first thought. As long as you put them straight onto an unsaturated backplate they do tend to stay there. My initial concerns came from putting them on saturated plates, at which point they love to jump around. This is also true for any question on field uniformality; providing the flux paths don't saturate, all the flux tends to spread itself out in a fully uniform manner as it emerges into the gap.
best regards,
Chris MB.
Post by Chris Bradley » Sun May 24, 2009 12:46 am
So I have an update on this, having found a little time today to knock up some metal plates to test the essence of the idea. I am not well equipped with tools nor have facilities, so it was all I could do to make these 4 150mm x 150mm x 2.5mm steel plates in the time I had. That being said, Maxwell SV doesn't suggest there is much to gain, in terms of saturation, in having any more thickness.
Pic 1 – general view of the thing I've made – steel top and bottom plates with neodymiums between them. Each is 22mm diameter and 20mm high and they are stacked on each other making 40mm gap. There are two such pairs at each corner, making a total of 16 of the 22mm x 20mm magnets.
Pic 2 – a close-up. The studding is [non-magnetic] stainless steel. (These didn't actually seem necessary in construction, see below.)
Pic 3 – a lash-up quickie magnetometer using a A1302 Hall effect sensor (http://www.rapidonline.com/netalogue/specs/82-1020.pdf). These are around 1.3mV/G sensitivity. Power supply to the part set so as to read 2.50V with no field.
Pic 4 – ~1” outside the assmebly, 2.26V == 185G
Pic 5 – at edge of assembly, 1.41V == 840G
Pic 6 – ~1” inside assembly, 1.29V == 930G
Pic 7 – at centre, 1.27V == 950G
Pic 8 – on top, 2.74V == 185G
Pic 9 – I disassembled it afterwards.
Pic 10 – a simulation, as per a diagonal cross-section, using Maxwell SV.
Figures are approximate, of course, the device's tolerance being “1mV/G to 1.6mV/G”, but it gives some indication of the cut-off at the edge of the assembly and uniformity within. I still wonder if a bigger thickness of plates would help keep yet more of the field in, though Maxwell SV doesn't indicate any big advantage.
Assembly was a piece of cake. Supported on the studs, so that the plates were loose but retained, as I brought a stack of two of the neos up to the plates, they kinda 'snuck' into the gap without any fuss like they wanted to be there! Nothing dramatic, just a sharp, easily anticipated tug as they get close - as you'd expect from these magnets. Same with the next, etc.. Once inside they could be pushed around with a bit of force, but without too much problem. I could push the pairs right up close to each other without them repelling (as you can see in pics). By the time all 8 pairs were in place the whole assembly was quite rigid. There was no need to tighten the bolts up. In fact, the plates' holes had gone slightly off-square with each other and the bolts wouldn't actually tighten up easily! I had to knock the assembly on the floor several times to nudge the plates over to get the holes lined up! So the studs seemed to be redundant, though they usefully held the plates in alignment as the magnets were introduced. (I did clamp them down then, just to make sure the magnets didn't move.) Disassembly was a breeze – just push the pairs around to give some space to get a good hold, then just yank the pair straight out, in one quick movement.
I'm pleased with it. OK, 0.1T isn't going to get you into high energy cyclotron territory, but that much field with plenty enough space for a 50mm radius could, e.g., give you >1keV protons. Given the relatively small volume of magnetic material to permeate such a large volume, I think ~0.1T is quite a sound result in this case. With some pole-pieces, as suggested in the pic of the first post of the thread, then higher fields would be expected. I think the sharp cut-off at the edge of the assembly, and the field uniformity, suggests the approach is working 'as planned'.
Dan Tibbets
Post by Dan Tibbets » Sun May 24, 2009 8:19 am
~ 1000 Gauss fields with perminate magnets- I didn't know they were that strong.
Dan Tibbets
Todd Massure
Post by Todd Massure » Sun May 24, 2009 4:46 pm
Thanks for the report Chris. Very interesting.
You probably know this already, but it's my understanding that there's nothing to be gained from stacking the neodymium magnets - in other words putting them in series doesn't add to the total flux in the magnetic circuit.
I would be curious what the field would be with all of the magnets making direct contact with the metal plates. Of course the smaller gap would change things a lot too.
Anyway, once again, nice work.
Todd
Post by Chris Bradley » Sun May 24, 2009 5:01 pm
Maxwell SV suggests there is little difference to the internal field, however many you stack, it's just a bigger width across which that field is established. More room to 'do stuff' inside that volume! Three magnets might come apart as I push them around, and one wouldn't've given me enough space to get my hands in to pull 'em out! Maybe I'll try to build with just one and re-measure.
Post by Chris Bradley » Sun May 24, 2009 5:48 pm
At some small risk to life and limb (namely, two small blood-blisters later) I re-did the above with 1 layer of magnets. As presumed – very fiddly! Two seems a good compromise!!
Pic 1 – at edge == 1090G
Pic 2 - at centre == 1120G
so a little more, much as Maxwell SV indicated - Pic 5
Pic 3 – I added two more of the magnets either side, so from 8 magnets to 12.
Pic 4 – now indicating == 1700G
Now I have to try to take them apart... there is quite some field strength around the edge to battle with... (edit - got them apart, not as easy/safe as with the two-stack. I noticed one felt like it might have been reversed when it came out, which would've acted to oppose the others)
