Argon Tube Power Source
Re: Argon Tube Power Source
ok, i have to ask, why do you use a 40 watt lamp as a current limiter? why not use a heavy duty resistor? yes you would still have thermal issues with the resistance, but it would be way more stable that a lamp filiment.
also, have you tried any other type of load on the output side of the circuit? how well will it run an inductive load? (motor)
i agree, unless you have the correct test equipment, under good calibration, AND use it properly, any measurments taken are useless. however, i would think that getting a rough idea of the input power would be a necessary first step. (even if you cant afford an oscilloscope, perhaps you could borrow one? most schools will have someone around that would gladly help you test this device out)
just some random thoughts...
Q
Q
That variac buzz could be an approaching resonant point and you can really be fooled there with energy distribution. Make sure your brush isn't dancing around in arc mode as well.
So many unquantified reactive variables here.
I'm using light bulbs at the moment because its the easyest source of high power resistor I can get. Radio Shack don't carry high power resistors. And bulbs are cheap at Canadian tire. 4 for 89 cents.
Today I have been making some more intensive measurements, still runing a 100 watt bulb.
On the DC end I measured 330 VDC @ 175 milliamps. That works out to 57.75 Watts input. On the AC output end entering the 100 watt bulb, I got 155 VAC @ 520 milliamps. that works out to 80.6 watts.
The frequency was at 200 Hz so my meter don't react fast enough to the pulses, so I suspect the AC readings should be slightly higher.
Still studying this phenomenon, will keep you updated. Harold
Perpetual motion. Bah.
I have been doing some detailed measurements in the last few days, sure time consuming.
Anyway below are two charts of the detailed measurements taken.
The first one is using 100 watt bulb as output.
The second one is using 2x100 watt bulbs in parallel.
The 2x100 watt bulbs didn't recieve enough current to light to full brightness, but the tube tried it's best. Ran very well.
The measurements are arranged in increasing order according to what the AC output of the tube was. As my tube slowly looses vacuum the AC voltage goes up. So it appears that the higher the vacuum the lower the power output. The output current and voltage goes up at a steady rate until the vacuum is to low to sustain the discharges. If I could build a tube that didn't loose it's vacuum, it could be tweeked to get the best output to input ratio and sealed at that spot. A glass discharge tube should do the trick, but I don't have the glass blowing tech. needed. Anyway below are the measured resaults.
And to the preveous replyer, this isn't perpetual motion, but the conservation of energy, energy can neither be created nor destroyed, only converted from one form to another. These tubes are collecting some form of energy and converting it to electrical energy. I don't believe in any form or perpetual energy, but I have read that the amount of cosmic energy bombarding this earth 24x7's is enough power to light 1.5 million 100 watt bulbs for each man, woman, and child on this earth. All we need to do is find a way of converting cosmic radiation into usable electricity and all our energy problems would be over. Thanks for the replies and keep experimenting, the answer to endless energy is out there.
Till later Harold.
Till later Harold.
I'll bet you used a real nice digital multimeter to take these measurements; didn't you?
It lied to you, of course. All of your measured figures are in error! A good engineer or even a technician would know that.
None would have consulted a digital volt and ammeter to read or record data from this circuit. They would realize that the meter would lie through its teeth, based on some silly averaging the factory provided (like for pure, in phase sine waves of voltage and current).
The factory did its best, but they assumed a certain knowledge on behalf of the user, (always dangerous - assuming).
Only a 4 channel high speed data logger system taking about 10,000 samples or more a second for voltage and current in and out of this system and calculating and plotting the wattage 10,000/sec will come close to telling the real story here. You would find the Pin vs. Pout curves so generated to nearly overlap (true conservation of energy.)
This is the real stumbling point with the new energy crowd..........They use electronic meters to record their electronic data in circuits that go buzz, bang, boom, pop, arc and fizz. Somethng the meters were never designed to do.
Note* Some bench top O'scopes in the $3000 class have a single computational trace channel where channel one can be assigned voltage and channel two assigned current and a third channel will compute and display real time power (E x I).
But, why blow the big bucks when a $600.00 "pico scope" hooked to a computer will do all this for you (provided you are not getting microsecond events in your power data.)
For a real insight into real data logging done on supposed overunity systems go to:
http://www.earthtech.org/experiments/index.html
This is the Earthtech site. These are real new energy researchers with a decent budget, plus, they have brains and knowhow. They are looking at only new energy devices and systems. They, unfortanately, are not seeming to find any. Look, especially, at their carefully conducted experiments and data logged Pin/Pout results.
These folks are honest and damned good at what they do. They do only one thing for their paychecks.......the test for the veracity of overunity systems. Their "money source" demands that they do only that.
It is downright amazing how those Pout plot reuslts are always just below the Pin plots.......They move on, in their plodding way, to the next overunity claim and take it from the top, (carefully), yet once again.
I tested one of my other tubes to see what readings I would get with it, and I got very close to the same type of readings with it.
Because of the higher current output I was getting from the tube with 2x100 Watt bulbs connected, I tried using 600 watts for the output, and the current readings I was getting (with the vacuum set right) were averaging about 1.25 amps at 175 Volts. That's 218.75 Watts output. And my input measurements were about 175 Volts at 225 mA that's 39.375 watts input. This means I am getting 5.5 times the wattage output to the wattage input.
That's 450 % over unity.
I tried hooking up a 1000 watt baseboard heater to the tube and I still got about 1.25 amps, so it appears this is the maximum current the tube can put out. 1.25 amps. But the most interesting thing is the input voltage and current didn't change when I connected and disconnected the higher load, even with the 1000 watt baseboard heater connected.
Even if I'm not using $600 meters or high cost oscillascopes, these differences are to high to account for because of lack of accuracy.
I am starting to wonder about the people on this forum, how much more proof do you need. When I had one 100 watt bulb connected I was typically getting 50 % over unity, when I tried 2x100 watt bulbs I was getting 100 % over unity then when I used 600 watts worth of load I got 450 % over unity, how long will you guys refuse to accept the obvious. Sorry for getting so exited about this, but there is a point were common logic has to kick in. I am using 5 different meters from 4 different manufacturers, I am using both analog and digital meters, and still get the same typical readings.
450 % over unity is just to large a difference to logically dismiss because of poor equipment.
Com'mon man were is your logical common sense gone. I could understand the 50 % over unity as an error but not 450 %.
And I had the tube runing for a good 3 hours taking measurements, this isn't a breif reading this is a steady average reading.
And even with the vacuum not set just right, I almost always get over 2.5 times the output to input, with the 600 watt load connected. So greater then 150% over unity is the norm for this tubes output.
Till later Harold.
Till later Harold.
- Adam Szendrey
- Real name: Adam Szendrey
Harold i appriciate your enthusiasm, but it is obivious that nothing has been prooved, exept for the fact, that you don't have the proper instrumentation and knowledge to verify your own claims. Yes that is harsh, but that is the way i see it. You have been told SEVERAL times in this thread, that you should use a high sampling rate data loggign system, or a good digital o-scope, but you simply ignore it, because you WANT your device to work...it would be great, i would love a portable source of endless energy, but desire and fact are usually not overlapping.
Simple multimeters (digital or not) CAN produce such different readings, they proove nothing at all.
If you'll ever power this device via it's own output (or at least provide reliable data), i will (and i think all of us) accept that it can tap into the ZPE, active vacuum, or whatever we call it.
On the other hand Harold is right about over-unity. There is no such thing, energy is always conserved, BUT where that energy comes from is another matter. In an "OU" device the energy comes from a source we are not familiar with, that's all, the device itself can be thought of as a kind of "transistor".
Oh and science...it IS faith...
Adam
Adam
My reason for posting on this forum is because I realized that anyone who is trying to build a fusor, probably already had everything they need to build one of these Argon discharge tubes. But they may not have all the equipment needed to build a fusor yet. So in the mean while as a side project they may want to build and test one of these discharge tubes out. Good way to get your feet wet in working with vacuums and how to get the power to the components in the vacuum.
Maybe someone who has a good 4 input scope can build and test one of these and give us pictures of the scope waveforms. I have my own scope but the power supply transformer for it burned out and I haven't been able to find a schematic for it to get the transformer specs. If I knew what the transformer output voltages are supossed to be I could design another power supply for it. I spent a few hours on google looking for leads but didn't come up with anything. I had the scope given to me by my boss when I worked as an electronic tech. a few years ago. The only model information it has on it is Samick 505, which is printed on the front of the scope above the display. No other model info found anywhere. If anyone has one of these of there own let me know.
I'm sorry I can't satisfy the skeptics on this forum with high quality measurements that satisfy there requirements, at this time. I am trying my best, with what I have. Maybe I picked the wrong forum to join, I found no one else that's interested in this project, I only got skeptisism. I hoped to find some pioneer spirit from someone on this forum, but even after my measurements got 5.5 times the power out, no one is willing to give this even a little more consideration.
They just pushed it off as poor measurements.
I think Adam Szendrey said it best. " Oh and science...it IS faith..." so like any other religeous fanatic, if someone comes up with something that violates your faith you just brush it off as a falsehood, without giving it a second thought.
Sorry for waisting your time and forum space, I will look for a more receptive group on another forum.
Bye for now Harold
Bye for now Harold
Harold - many folk on the forum are deeply involved in the persuite of Fusion and commit there time and efforts toward this. All have their own opinions but respect any ideas from whatever source. I have equipment to test your project but would find it a diversion from my own direction. This is not from disrespect of your ideas but my own agenda priority. BTW you can obtain ready made glass plasma tubes. - try contacting the seller of a tube I had bought -- ebay 7551176344 - he will supply others. { you will notice from the date of the win - it was before your original post. Many of us try many things }
Harold - take your device to the nearest college or University that has an electronics lab. If you invest a little time ingetting your measurements done correctly, you will see, that this part of "Science" is not really faith, but careful, cautious, methodical testing. One forms a theory or premise partly in the belief that the evidence leads that direction. He then (if he is a good scientist) carefully tests his theory and tries every possible wasy to disprove it. Only when he fails to prove it wrong or explain by prior concepts, does he tentatively offer the results for others to consider.
Do the scope measurements as we have suggested, and you will see what we are talking about. Digital and Analog meters can be very misleading in what they present. Comparing peak derived average or RMS data with DC average data in even a simple 1/2 wave diode rectifier circuit feeding a load, will produce similar results to yours. And those numbers are wrong. I have taught electronics for years, at Jr. College level and this is one of the pitfalls of instrumentation that we train the students to avoid.
The answer is very very simple. If you are getting 450% over unity, then power your input from your output.
Marvin, you know they will never do this! It would be far to telling! It would burst a bubble so important to the needful. The needful of hope, of a brighter future, of a faith in man's power over his environment and ultimately over even the laws of nature.
We are, indeed, the smallest of mighty things.
or in Irish - ' Mighty Small '
I'm sure youve seen the pattern before, from the tentative "I think Ive discovered a new power source, I can generate small excess power according to my calculations from these measurements" which gets a cynical response and quickly changes to "My calculations show massive amounts of excess power from these brand new measurements" and which quickly deterriorates to paranoia and conspiricy theory psychosis "You are all trying to supress these results to protect your precious science/Oil profits", go away angry that noone will help them make the one bit of kit they can't design themselves - the 'trivial' part that converts the output power produced into a form compatable with the input. In this case thats not really hard. Any EE could make a convertor efficiant enough to fufil the given voltage/current specs, trouble is his criteria for a working convertor is that it produces perpetual energy when combined with his circuit not that it actually converts the voltages he says he needs efficiantly. Hows about that, you build an arc circuit that magically creates excess power, violating the first rule of thermodyanics, and in the same attempt you manage to make a convertor that destroys more energy than you can make also violating the first law!
I love the way that creating 50% excess energy might be seen as weak proof that his system is overunity, but that he can show us numbers that produce 450% excess energy which he thinks makes his case stronger. I also love the way that a system that makes energy out of nothing seems less plausable than a system that boosts a primary input power. Ive also seen people do the math for running heaters based on the input coming from mains, completely oblivious to the concept that if the output really is more then you can run the input from the output and the power is therefore 100% free.
175V step up is pretty easy, not like the homopolar generator crowd. They have maybe half a volt (Its been a long time since I argued with one of these types and I can't say I miss it much) at thousands of amps and they cant figure out how to use that to run the high power mains motor. Stepping up half a volt at that sort of current must give EE's screaming nightmares.
Maybe there's a moral in all of this. People that expect something for nothing deserve everything they get.
Hi folks:
Same old dance ... Same ole results resonate tanks don't generate any thing extra. 40 years and counting!
Happy Fusoring!
Larry Leins
Fusor Tech
Happy Fusoring!
Larry Leins
Fusor Tech
You guys gotta' admit though,.... It is easy to get into the new energy biz! A few basic circuit components, two or three papers off the web telling you how to do it and you are off the the races.
I have poked around in and amoungst the new energy folks for about 30 years, (never actaully being one myself), all the while, calmly listening and absorbing.
The common thread is that "THIS NEW THING!!!" will blaze onto the scene like a brilliant comet and the energy of the masses assembled will rise to a near fever pitch within the community and far more quietly....almost with a whimper, ebb.
Two years later, you go back to the idea's most vociferous proponents and inquire of it. You are told, "OH yeah, I heard they lost their funding".......or........." I think that guy's device and patents was sold to a japanese company"..........."BUT...HEY! YOU GOTTA' SEE THIS NEW THING"........."It is way better and much easier to make than that other device........
Sound familiar? Sound a bit like the fusion mantra? We are only being asked to standby for the latest break through.......
The above is the recurrent theme throughout the new energy community and crowd.
The "Grey Motor" was a big deal in the late 60's and early 70's, but it died the natural death it deserved then. Now, there is a fresh resurgence of adherents and tinkerers out there looking at the Grey Motor again. So, within the community, if there is a lull, they can always have a re-vival based on old time religion to hold onto and re-energize the faithful.
These are my own personal observations and come from a rather jaded and jaundiced, watching eye, but a listening pair of ears coupled to an ever slowing mental faculty.
There is absolutely no difference between these new energy guys and the normal fusion community involved with ITER, NIF or any of the other systems save that the latter have cache', training, funding, knowledge and public acceptability via media hype. Everybody is spinning their wheels and plucking our nerves. One group is accepted, the other not.
