Physics - the prime science of nature and nuclear physics
Re: Physics - the prime science of nature and nuclear physics
Light and all Electromagnetic Radiation is the result of an electron or a whole bunch of them either being accelerated, decelerated or are in the process of changing direction. Electromagnetism is a bunch of electrons in uniform motion moving through a conductor. A so called Permanent Magnet is some piece of fixed matter in which imagined domains of atoms are magnetically locked in a manner such that those domains are forced by some exterior source of energy to magnetically align the majority of those domains in an overall additive predominant direction to create a relatively permanent magnetic field once the magnetizing force is removed.
It's all about electrons in our world at STP. They are why stuff is solid....Why stuff is opaque....Why stuff is transparent. They make the light at all frequencies which determine why things appear transparent or opaque.
Electrons determine bulk charge as to whether an item is positive or negative relative to another charged body. All of chemistry is electronic in nature.
Protons and Neutrons are uncovered at 13ev for hydrogen in the case of the proton, and at MeV energy levels for all other elemental nuclei. This energy is quite far above STP conditions The nucleons role in our STP world merely determines what element we are looking at and whether it is radioactive or stable.
The electrons rule all else drools....
The electron has no role at all in nuclear physics which deals with nucleons far above STP energy levels. That's why they use the word "nuclear" in that field. To play in that world, bring a whole bunch of energy to the table or milk it out of the naturally radioactive elemental isotopes.
