Update on experiment
steventw
Real name: Steven Whittam
Post by steventw » Wed Jan 22, 2020 7:11 am
Hey
Just an updated on how I’m doing with experiment
Got down to 2812 micron with just pump
Friend at work as a vacuum pump so hopen to try double up.
Pump he has is better than cheap chines one I’m usen.
But slowly getting there
Re: Update on experiment
Post by Richard Hull » Wed Jan 22, 2020 7:39 am
You do have a nice gauge, at least. You also have either the worst pump in the world or the most number of leaks, real or virtual, that I might imagine.
steventw
Post by steventw » Wed Jan 22, 2020 7:54 am
I do Probly need a new plastic rim
Cause is a bit dodgy after didn’t put lid on right and lid got sucked in and ripped plastic seal in some places
Post by ian_krase » Fri Jan 24, 2020 7:56 am
Vacuum seals must be nearly perfect.
While compressible rubber seals such as O-rings with vacuum grease can cover many ills, they are still sharply limited. It only takes a small pinhole to make a vacuum unusable. Threaded pipe fittings, hairline cracks and pinholes, and a variety of other problems can also be an issue.
steventw
Post by steventw » Thu Jan 30, 2020 3:27 am
Just got a new seal for lid
Will see how it gos when get a chance to run another test
Will check fittings ect aswell
Post by Rich Feldman » Thu Jan 30, 2020 4:02 pm
Good luck with that, Steven.
As Richard said, your very high ultimate pressure indicates that there's at least one major vacuum leak. It's happened to me. Have you tried listening closely to locate the leak?
Another way to measure the leak is to turn off the vacuum pump and see how fast the chamber pressure returns to atmosphere.
Some pump defects can let pump oil be sucked into the evacuated chamber when motor stops.
If that happens in your case, you can valve off the pump instead of turning off the motor.
Here is an effective but messy method for gross leak detection.
Brush some oil or grease or petroleum jelly around the outside of each seal, while chamber is pumped down.
Watch through your large clear lid, to see where the oil & maybe tiny bubbles are being sucked in.
Watch the vacuum gauge in case pressure drops when the leak is momentarily plugged with oil.
Don't overlook the joints in pipe between pump and chamber.
steventw
Post by steventw » Thu Jan 30, 2020 9:42 pm
Thanks for advice
I’ll give it a go next time am at work in workshop
steventw
Post by steventw » Sat Mar 14, 2020 12:16 am
Hey
Update with how been going
Last few tests only been getting to around 4.9000 mbar
Guess still some leaks
Probly need to wash seal to get any dust off
Anyway attached some pics
Post by Rich Feldman » Sat Mar 14, 2020 12:47 am
Very nice pictures, Steven.
What if your leak is not from a dirty seal, but some place completely different from the seal you are thinking of?
Like an electrical feedthrough, or a vacuum hose connection, or you just have a defective vacuum pump?
Would be nice if you could close a valve between pump and chamber.
steventw
Post by steventw » Sat Mar 14, 2020 2:11 am
Hey
Attached picture of setup
Basically just a big pot with Perspex lid with rubber seal
Pump is rated to 3x 10-1 pa
Not sure what that means
