Forced vibrations in EM-wave? What will happen?
Sven Andersson
Real name: Sven Andersson
Post by Sven Andersson » Sun Oct 02, 2016 6:25 pm
Let's say we have a charged elementary particle such as an electron at rest that encounters an EM-wave. The result will be that the particle will oscillate up and down (if E is "up") and also be dragged along the EM-wave. It should move as a sine-wave I think, inside the sine-wave of the EM-wave. With the same wavelength as the EM-wave or?
However, let's assume that some force is acting on the particle making it oscillate with a different frequency; e.g. it may be coupled to another oscillator. What forces will then act on the particle? Will it be dragged along the EM-wave or pushed backwards or be forced in some other direction?
Re: Forced vibrations in EM-wave? What will happen?
Post by John Futter » Sun Oct 02, 2016 6:31 pm
Yes
Noah C Hoppis
Real name: Noah C Hoppis
Post by Noah C Hoppis » Tue Oct 04, 2016 2:58 am
Sum the vectors to find the resultant. Quantum mechanics makes things more nasty, but if you've chosen to work with an electron as a particle, forces still play relatively nice.
"No missile ever flew before 10 pm"
Jeroen Vriesman
Real name: Jeroen Vriesman
Post by Jeroen Vriesman » Tue Oct 04, 2016 12:38 pm
Hi,
depends on what it is you are asking.
"electron at rest", at rest for some observer? If the "EM wave" is seen as a photon there is no interaction if the electron is free (simultaneous conservation of energy and momentum is not possible for an interaction between a photon and a free electron).
If the electron is not free, there are also several possibilities, when it is bound to an atom/molecule it can change between states by absorbing a photon, when it's part of the free electrons in a material there is scattering.
When there is a standing wave of a low frequency, the E-component of the field introduces a force on the electron, maybe that is your question? The other force you ask about is just superposition. If the electron is accelerated it will start to emit EM waves itself (that is... if the Wheeler-Feynman absorber theory is wrong and radiation is produced by linear acceleration of charged particles...)
so you question seems to give more questions.
Is there a question behind the question? What is it exactly you want to know?
Sven Andersson
Post by Sven Andersson » Tue Oct 04, 2016 3:02 pm
Jeroen Vriesman wrote:Hi,
I don't know what I'm asking. I must study physics to able to ask anything relevant. But thanks for your reply anyway!
Sven Andersson
Post by Sven Andersson » Tue Oct 04, 2016 6:49 pm
Sven Andersson wrote:Let's say we have a charged elementary particle such as an electron at rest that encounters an EM-wave. The result will be that the particle will oscillate up and down (if E is "up") and also be dragged along the EM-wave. It should move as a sine-wave I think, inside the sine-wave of the EM-wave. With the same wavelength as the EM-wave or?
I withdraw the questions!
Sven Andersson
Post by Sven Andersson » Tue Oct 04, 2016 6:55 pm
Erwin Schrödinger, of cat fame, once cursed himself for not knowing more math! I must hereby do the same for not knowing more math and physics! If you could only scan into your head every page of those books on advanced calculus and analysis. But there is no royal road to...
Post by Dennis P Brown » Thu Oct 06, 2016 11:15 am
A free electron that experiences an electric field will be accelerated. This in turn will cause the electron to create its own field. This is found in any elementary physics text and does not require calculus. If the field oscillates, so does the electron whether bound or free. Of course any bound electron will respond very differently then a free electron and that can get very complicated and can require advance physics found in a junior level E&M book. Issues such as the frequency matter a great deal and especially if relativistic effects will occur.
Sven Andersson
Post by Sven Andersson » Thu Oct 06, 2016 4:44 pm
Dennis P Brown wrote:A free electron that experiences an electric field will be accelerated. This in turn will cause the electron to create its own field. This is found in any elementary physics text and does not require calculus. If the field oscillates, so does the electron whether bound or free. Of course any bound electron will respond very differently then a free electron and that can get very complicated and can require advance physics found in a junior level E&M book. Issues such as the frequency matter a great deal and especially if relativistic effects will occur.
Jeroen Vriesman above claims that a free electron cannot interact with the oscillating fields of an EM-wave, when seen as a photon. So which is it? Can it interact or not?
But a photon can undergo Compton scattering with free electrons, if I'm not completely misinformed. I don't get it.
Generally there is a lot on info on the net on how accelerating charged particles must emit EM-radiation. But not much on how charged particles then interact with those same photons!
Post by John Futter » Thu Oct 06, 2016 6:57 pm
Sven
Please stop re-quoting others material in each of your posts.
We can all read the previous post so repeating it only fills the server with surperfulous twaddle and makes what you are trying to get at almost impossible to work out
