Cheapo moderator / shield
myID
Post by myID »
What about using used deep fryer fat?
You can get it for free, it is solid (more or less), can easily be filled in whatever form you need and it is some sort of hydrocarbon so it should give a nice moderator right? And in combination with some borax (and lead) it should give a nice shield also.
Kind regards
Roman
TJA
Re: Cheapo moderator / shield
Post by TJA »
Provided you don't mind the smell and the volatility.
Chris Trent
Post by Chris Trent »
I would really not recommend it.
I make Biodiesel from the stuff and can say that it is very prone to being very messy. At least here in Texas it is also liquid most of the time. (Doesn't smell too hot either)
Good vacuum technique involves keeping things as clean as possible. A bunch of grease around does not lend itself to that. (gets everywhere and is hard to clean)
Bulk Paraffin blocks are a much better option, even if they cost a bit more.
Starfire
Post by Starfire »
Water is best and cheapest
Carl Willis
Real name: Carl Willis
Post by Carl Willis »
Hi Roman,
I recommend water or HDPE for a moderator. Neutron shielding is really not a concern.
Carl Willis
TEL: +1-505-412-3277
mej33
Post by mej33 »
I was doing some searching on this subject and came across
http://www.silpak.com/products/47-polye ... -polyester
as a product, and several references along the lines of (search for boron on the following link)
http://www.freepatentsonline.com/6497645.html
There are several advantages to using WEP (Water Extended Polyester) as a matrix to hold borax/boron. The major one is that is none flammable. It is low cost as far as resin costs go. The temperature before shape is lost is much higher. Water acts as a moderator. It is castable. It can be used by itself or after a water layer. The next layer would need to be steel for the gamma rays.
