He-3 Detector Operational and Background
ericstroud
Real name: Dr. Eric M. Stroud
Post by ericstroud » Sat Nov 08, 2008 12:17 am
Hi Everyone-
I was able to get my He-3 detector up and running, and some background counts were made.
The Hardware
Reuter-Stokes 3He tube P4-0820-103, from Don Orie, www.oetech.com
Tennelec TC175 preamplifier, from Don Orie
NIM Bertran 345 bias supply, +1700vDC
NIM Ortec 452 Spectroscopy amp, 20x coarse gain, 3uS shaping
NIM Tennelec TC246 windowed for gammas (not windowed in photo)
Ortec 5500 Multichannel Analyzer
I also use a Ludlum 2200 scalar/ratemeter windowed for gammas - which involves a lot less space, adjustment, and cables than the above! I highly recommend this portable device!
Background Check Data
All samples were 60 minutes at 1,107 feet above sea level on 07Nov2008:
Unmoderated tube: 10cpm (605 cts)
Polyethylene sleeve on tube: 10cpm (623 cts)
Paraffin moderator in acrylic: 9cpm (562 cts)
1/8" lead sheet around tube: 8cpm (509 cts)
Kindest regards,
Eric
Re: He-3 Detector Operational and Background
Post by Richard Hull » Mon Nov 10, 2008 4:01 pm
This data sounds good. How long is the tube?
I like to hold an intense gamma source near the tube and set the level detect to well above the gamma level "grass".
ericstroud
Post by ericstroud » Mon Nov 10, 2008 4:35 pm
Hi Richard-
This is the usual 22" tube from Don Orie. Timing was good, as I think he is currently sold out!
As you suggested, I will put a small gamma source before the next run.
Kind regards, Eric
Post by Richard Hull » Mon Nov 10, 2008 7:30 pm
A large Gamma source should make virtually no difference in the count if the discriminator is set correctly.
My He3 counter tube is also 22" long. I get between 4 and 7 CPM taken over a period of10 minutes. This has been as high as 25cpm during the great November CME of a couple of years back. Solar activity definitely affects background. That is why I do a 10 min background both before and after a fusor run. Background subtraction is not really all that important anymore with 3000-4000cpm being the norm for a moderate fusor run.
When I re-vamp my area for fusor IV I hope to have the He3 counter a good bit farther back.
