Any info on the Canberra Acquisition Bus ?
ChrisSmolinski
Post by ChrisSmolinski » Mon Feb 05, 2007 2:52 am
Yes, I'm back to playing with my 8076 NIM again. Thanks to some docs
from someone, I'm a lot closer to getting it to work. I had previously
figured out how to control most of the settings, now I have that done, and
am able to get conversion data back from the unit. I'm curious if anyone
has any docs on the format of the data over the CAB. I'm going to connect
a pulser to the input and see if I can figure out the data format that way,
but some actual info would probably speed things up ;-)
8076 modules seem easier to find than 8075s. Once/if I get this working,
I'll release the software I'm writing for it. Very simple interface, runs under
DOS and you just need a parallel port and a simple cable. Next step may
be a simple PIC uC circuit so you can talk to it via USB, and then have
some nicer GUI software.
Starfire
Re: Any info on the Canberra Acquisition Bus ?
Post by Starfire » Mon Feb 05, 2007 7:19 pm
Look forward to that Chris
DaveC
Post by DaveC » Mon Feb 05, 2007 8:11 pm
What vintage is the 8076, Chris? Also, have you talked with Don Orie? He may have a manual, with I/O info.
Mitya
Real name: Dmitry Schwarz
Post by Mitya » Mon Sep 14, 2015 4:39 pm
Where to find documentation to ADC 8076, I bought it, but the problem with the documentation ...
Post by John Futter » Tue Sep 15, 2015 9:50 pm
Mitya
you should get your answer in 2023 if karma exists
Please do not bring old threads back to life
please read the forum rules and introduce yourself and supply your full real name in the required fields
