BGO hv convert
Posted: Tue Jul 18, 2006 1:08 pm
by Tman
I have two of the same BGO detectors as in Carls "micro" BGO detector post. The supplied socket is in the -HV configuration, I know this must be pretty easy, but how can I convert the -HV over to +HV so I can power it with a normal power supply.
Carl mentioned earlier that he externally converted one of his over with a few capacitors and resistors.
I will be rewiring my other detector to 144M so it will work for survey meter use.
-Thiago
Re: BGO hv convert
Posted: Wed Jul 19, 2006 12:36 pm
by Tman
Ya, I think I'll change the resistance down closer to 100M.
But does anyone know how to convert +hv to -hv?
My power supply has +hv and ground leeds, and my detector has -hv and ground leeds
-Thiago
Re: BGO hv convert
Posted: Wed Jul 19, 2006 12:47 pm
by Richard Hester
Once you rearrange your dynode string and coupling cap the way they should be, the PMT will be ready to accomodate a +HV supply at the tube anode and a grounded photocathode, rather than a photocathode at -HV and an anode at ground. Check out the Burle web site for a huge application note on PMTs and how they are used.
Re: BGO hv convert
Posted: Wed Jul 19, 2006 4:11 pm
by Carl Willis
Hi Thiago,
I got your email and do intend to answer it. Just haven't had a spare moment in the last couple days. The negative HV socket assembly that comes with the tubes contains just about everything except two caps and two resistors (if you want convert to run pulse-mode, positive HV). Sorry for being unresponsive. I will get a schemat for you if the other guys haven't already.
