Radon detector for under $100.00
- Real name: Jon Rosenstiel
Re: Radon detector for under $100.00
I've had my series III for almost two weeks now, about ready to whip up a report on my radon levels here.
One thing I did note, the initial reading was fairly high, then steadily dropped as the days ticked by. (Though my initial reading was only1.9 pCu/l, not the 38.5 you got)!
Jon Rosenstiel
Jon Rosenstiel
- Real name: rich normand
If you read my previous posting you will see I put my series II through hell in my sample box. May I suggest you put your unit several days in a well-ventilated area and see if it goes down to a 0 or 1 reading. This will ensure it is actually working properly and not contaminated.
Only then, I would bring it down back to the basement. If the high reading persists then count yourself lucky to have found it at this time and be able to take remedial action.
Wow, Tom! That is a gang o' radon for a basement living space. I though only folks in Pittsburgh had those levels!
Actually, I found about 40 homes in and around Richmond with those levels on the Radoneaze website.
http://www.radonease.com/
Most are in south Richmond on the edge of the Amelia pegmatite dykes, (thoron, Ra220).
Pittsburgh had basements in the thousand pCi/l range!
Still, I would not want to spend more than a few hours/week in a 40 pCi/liter basement.
The 4pCi/l federal safe point is for a 24-7 dwelling and living level. The gas is heavy and in a calm basement it probably won't invade the upstairs. I would only be concerned if a wipe test yielded obvious levels of depositied daughters.
Setup a GM counter (must be mica windowed) outside or in a very low background area. take a 10 minute background reading using a physical counter not a meter.
Take a normal paper towel and fold it over 4 times so you have about a 4X4 wipe. Wet it and take it into the basement and wipe a low lying long straight stretch of something. (floor, table rung, etc.
Place this quickly under the GM counter less than 1cm from the mica window and reset the count. Measure for 10 minutes and compare to previous background. This is a crude, qualitative, no long term wait, test for significant radon levels.
Doing this wipe in many homes on the face of an old analog TV that has been on for >1hour continuously will often shock folks.
The TV test is NOT an indicator for high radon levels as it is electrostatically attractive over large volumes of atmosphere. Only the quiet area wipe test is good.
I got a 48 hr radon level of 7.2 pCi/ liter in the living room today. Then I realized that the shelf that the detector was sitting on was really dusty. So I dusted it off and started a new run.
I did a qualative vesion of the mica window GM count test suggested by Richard (I had no problem finding lots of dust to pick up in the house) and there was qualatively at least a 2X increase in the counts when exposed to the dust.
Tom Dressel
Tom Dressel
2X on a broad dust wipe is not too bad in my qualitative estimate. I have wiped in my lab and had 2X off a low corner bench shelf. My main attached lab radon level is about 2-3 pCi/l (concrete floor) while my upstairs indoor dwelling lab level is 1-2 pCi/l. I try and make all quantitative radon measurements at about belly level with my pylon lucas cell instrument. Floor level could give some overly high levels and levels taken above the head level would be low most of the time.
I've had my Series3 sitting on a buffet in my living room for just over two weeks. It's initial reading was 1.9 pCi/l, but it has steadily dropped and now after two weeks has leveled off at 1.1 ~ 1.2 pCi/l.
I reset it and moved it to a 14' x 14' storage shed where I keep my small supply of radioactives (and lots of other junk). I'll post another update in a couple of weeks.
Jon Rosenstiel
Jon Rosenstiel
As of this writing I am having a sub slab suction system installed in my house to reduce the Radon levels. It consists of a 3" hole in the basement floor with ~5 gallons of dirt removed below the slab. The cavity is evacuated to the out side via a 3" PVC pipe and a fan. The goal is to establish a 2" water vacuum under the slab to prevent Radon infiltration into the basement.
Tom Dressel
Tom Dressel
I bet that ain't cheap! Good luck on your remediation efforts. In some special, sad cases, remediation can cost tens of thousands. You can't move away from the problem, for you cannot willingly sell a radon ridden dwelling without informing prospect ive buyers. Some folks who consider themeslves "there for life" will just either live with the problem by reducing time in the basement or seal the basement off from the upstairs.
Just out of curiousity, Tom, How long have you lived there and been suckin' down th' basement rads? Do you spend a lot of time in your basement? Often, it is the only place in the house that a hobbyist/amateur scientist has that his Mom/Wife will let them have.
Twenty one years of sucking bad air.
I don't spend much time in the basement now, but in the past I have spent hours down there watching TV and my wife now sits down there for hours watching DVD's.
$1,425.00 is not inexpensive, but remember the radon detector was under $100.00. At least now the house is sellable, and the Radon guy is confident that the levels will be below 2.0 pCi/liter in a day or two.
That is a very low price for the work done and product delivered, coupled with the peace of mind. It is comforting to know that at least one person directly benefited from this now long thread based on my original post. I am sure a lot of others who picked up the Radon Alert are better informed and happy they did.
A relatively inexpensive tool and instrument that looks at things unseen and reports to us on the world of radiation issues.
I am sure your levels will plumet. Radon remediation is often, just a matter of increased or improved ventilation rather than barrier blockage which is way more expensive.
Well, 72 hrs of sucking under the slab has pulled the Radon level in the basement down from 38.5 to 0.9 pCi//liter. Thats a 97% Reduction.
Remediation works!
Tom Dressel
Remediation works!
Tom Dressel
Looks like that little detector was agood investment afterall!
Yes, it was a good investment.
A frend of mine who has a cabin on the north shore of Lake Superior, bought a series III detector and found Radon levels at 177 pCi/ liter in his basement.
I can't believe the apathy amoung my collegues ( all physicians ) with respect to Radon. After my experience, I feel quite strongly that a question that every primary care MD should ask their patient during the annual physical is: Do you know what the Radon levels in your home and work place are?
Tom Dressel
Tom Dressel
Supposedly...............and I say, supposedly. Radon is second only to smoking as a causitive agent in lung cancer.
Whether this is an absolute fact or not is highly suspect. For I fear much of the data is based on old data where the population smoked a lot and others got a lot of second hand smoke plus there were high levels of other toxins. I am concerned that these elements could not be isolated enough to point 100% at radon as a causitive agent.
The only test I would ever accept is a control group that was 100% non-smoking and 100% not exposed to other chemical fumes in the work place being known to live in a highly radon loaded environment show increased cancer against a similar group in a known low radon environment.
Smokers vs. non-smokers is a no brainer, as the smokers willingly and gleefully exposed themselves every waking moment by setting tobacco on fire and sucking the burnt gases deeply into their lungs for that satisfying hit of pleasure.
No one would do that with radon and so such pronouncements such as "second only to smoking" for radon is highly suspect in my mind.
Still, erring on on the side of caution is also a no brainer. A 30+ pCi/l load is certainly not a happy living environment if it can easily be pulled back to 3 PCi/l. However, anything over 100 is a place you don't want to be for protracted periods. I bet a nickel to a doughnut that 10 p/Ci/l is just fine in a living space.
Some of the old U mines had daily working environments of 4000pCi/l! That is not a nice workplace. Of course 80% of those old miners smoked like chimneys, too! I was alive in the 40's and 50's and there were very few grown men who did not smoke. It was relatively rare to see a woman smoke then, but it became a common sight by the late 60's. Most U mines by the late 50's were well ventilated. I have an image taken deep inside the Mi Vida, where they have mined out a huge room (~40X40 feet?) and it is a formal welding and machine shop used to maintain the ore moving machinery. There are workers busy there at lathes and welding rigs. I don't think I would want to work in that shop, I don't care how well they ventilated it. I have seen movies of small mine operataions with the rock dust thick in the air. No one had on a respirator! How many radon induced cancers were logged here instead of being chalked up to direct dust inhalation or silicosis?
Here is another experiment for people with this neat detector. Usually it reads a constant 1 pC/l in the basement. However since radon comes from under the concrete slab I put the detector under a large beaker and over the basement drain. Here is the result after one week. now, since the drain has a water trap (and no smells) I have to assume this is coming from cracks around the fitting.
Good ole radon! It is for all God's chilluns. It is everywhere like any good boogie man.
I've got a 12' x 12' fairly well sealed-up storage shed in the corner of my backyard in which I keep my small supply of radioactives. (2 to 4 pounds of uranium ore and a few warbird instruments). My series 3 detector indicated around 9.5 pCi/l while in the storage shed.
I removed the radioactives from the shed and ventilated it for 1.5 hours using a medium sized fan. I reset the series 3 and closed up the shed. Two weeks later the indicated radon level was 1.9 pCi/l.
I then returned the radioactives to their place on the shelf and reset the series 3. Four days later the radon level was back up to 9.5 pCi/l.
I was stunned that my rather small stash of radioactives would affect the radon level that dramatically! I suppose a contributing factor is that the shed is fairly well sealed and is accessed only occasionally.
Jon Rosenstiel
Jon Rosenstiel
Interesting Jon.
I found similar effects in my basement.
You can look at my previous posts in this thread putting the detector in the sample box. No surprises there, up up, up and up. I now have the radium needles in a sealed jar.
A next post was with a beaker over the basement drain. Still no surprises there with high reading.
I then moved the detector outside (reading was 0, bear in mind I have the series 2 that does not read decimals and does the rounding the wrong way).
Back to the basement but in the living space. Three weeks later, it was at 3. Opened the basement windows and see, remember it is summer and the second floor windows are opened for ventilation. In effect, there seems that there is a vacuum created in the basement by the top floor venting the basement air where the cold air is. Therefore, I opened the basement windows and the reading went back down to one. I tried this scenario several times over the summer weeks with similar results. The radon reading will go back up on cool weeks when the ventilation is not as good.
Looks like the solution for your situation is to get better ventilation in your shed and seal the sources and open them outside.
Outside storage sheds are the ideal place for your U-rock mineral collections, warbird instruments and the like. There is no real hassle with even a 50-100pCi/l reading in these spaces.
A few lungfulls of this air is no big deal at all, of course. When I need the ole' lawn mower, I just go throw the doors open and walk away for a few minutes (talk to the nice lookin' babe who just moved in next door or sumpthin' like that.)
It realy only takes about 3.85X5 = ~19 days to get 98% all that radon back into the shed. Exponential growth........ain't it great? Well maybe in everything except kids.
It is good to remember that even massive lung loads to the tune of 1000pCi/l of radon are fine as long as you are just passin' thru. If one does the math, 1000pCi is 1 nCi and that means a mere 37bequerels/liter of air or 37 daughter product nuclei created per second in a lungfull of this rad-air. Also, remember that with each lung load, you exhale virtually 100% of the radon and the 37 daughter nuclei. It is that .00001% of product that remains over tens of thousands of lung loads that adds up in a living or work space. So 1000pCi/l is nothing to fear unless you are in it for a significant period of time.
The radon numbers game can be a fear factor or a scientific tool. It is important to do the calcs to get a clear picture of what the numbers mean rather than freak out due to the vast difference between the government's 4pCi/l spec for living spaces and a simple 400pCi/l U-mine that you are just pokin' yer head in for a few minutes.
Note and Warning: Some mines that are abandoned and have no forced air ventilation, as when they were in full operation, can easily go to 1 million pCi/liter!!! A few minutes in such a mine will leave you, your lungs and clothing radioactive with daughters. After a couple of hours outside, it will all be decayed away, but your lungs will have a very microscopic load of 27 year half life radio lead in them.
Well put, Richard.
When (or if) I ever make it to your place I'd appreciate it if you would point out "the nice lookin' babe next door".
Jon Rosenstiel
Jon Rosenstiel
Positron decay is found only in low z- elements where un-natural neutron irradiation is used to blast normal matter leaving it in an un-worldly state. There are no true long half-lived (10 year + ), positron emitters. Such matter seems an abomination to nature, therfore, she gives it little time in the universe.
Regular beta emitters can have very long half lives, though not traditionally epochal. Beta emitters of both types are all about neutron-proton balance within a nucleus. It seems that natural inter nuclear neutron decay is a much more leisurely process than pair production via positron emission which usually proceeds with some eager dispatch and only in low Z stuff.
It is important to remember that the proton building block for the neutron was already there in the nucleus. Pair production ocurred within the excited nucleus in such a manner that the proton-electron formed a neutron and the the positive charge lost to the nucleus as, presented to the universe, flew off in the postiron. the postiron is doomed of course and the mass balances as it is destroyed. It's positive charge disappears as well, BUT, the postive charge is retained by the proton in the nucleus which is now locked down in the newly created neutron.
Charge and mass are balanced for all FUTURE nuclear reactions within the nucleus. Mass defect energy is used up or stored in these processes according to e=mc^2. No real NET particulate mass or charge is created once the short period exchange process is over. Mass defect is juggled and played with however. Mass defect is a mass like item, but neither particulate in nautre or charged.
