Scintillator tests
Re: Scintillator tests
Post by Richard Hull » Wed Apr 10, 2002 2:51 pm
Thanks Tom! Richard Hester is looking for a schematic diagram for that preamp! If I ever made one, I lost it. (been a while).
That tube did not have a three transistor preamp. It had an RCA MC3486 or some such IC (transistor network) and one or two discrete transistors, if I remember correctly. If you have the schematic, get in touch with Richard.
thanks,
guest
Post by guest » Wed Apr 10, 2002 5:13 pm
The reason I am looking for the EMI/Thorn preamp schematic is that I am trying to grt a figure for PMT output current so that I can correlate the numbers taken using Richard Hull's setup with another setup. The SCA threshold and gain settings are known, as is the voltage output of the PMT/preamp combination. The only unknown factor is the currrent to voltage conversion factor for the PMT preamp.
