Re: Plastic Scintillator Preamp Circuit
Richard -- it might be useful to include the Power rail voltages -- I take it, that it is for a differential supply , but is it 12v or 15v or what ?-- because of the current balance,- does it matter? but nice a one and is most appreciated ---- have you a double sided PCB layout for this circuit? -- If not it may be interesting to design one -- ( if I ever get time ) regards John
The rail voltages are +/- 15V, though +/-12 would probably work as well, seeing as I took great pains to reduce supply sensitivity in the design. I would choose the higher rail voltges for a bit more dynamic range. The board layout I used was single sided. Though this goes against the grain of convention, it works well if the proper precautions are taken. The results speak for themselves.....
