Pulse generator
Pulse generator
I had a picture of the scope tracing from my primative pulse generator designed to test the NIM components. Richard Hull said that a good clean pulse generator is hard to build. I an starting to believe that it is impossible to build.
I was using a 555 timing chip to generate a train of square wave pulses then a 741 op amp to differentiate the squaer wave and generate a series op spikes. The problem is that the 555 chip puts out a bunch of high frequency noise in the DC power supply, and I just can't seem to get rid of it. By the time the signal is attenuated down to the milivolt level the noise level is horrendous. As a last resort I will try an optical isolater in the last stage of the pulse generator drven by a seperate power supply.
Any other ideas?
Tom Dressel
Any other ideas?
Tom Dressel
Re: Pulse generator
A 741 is a terrible choice for a buffer. The slew rate is pretty slow. I'd take your 555 and feed it through a fast CMOS gate. Try a 74HC(T)04 or a 74FCT04. You'll need really good decoupling on the buffer, and you might want to actuall use gates from two packages in series, with separate decoupling on each, if HF noise on the power is a problem.
How are you attenuating it? Are you getting noise in through the ground? Are you sure the noise is really there, or is it being picked up on the leads to the oscilloscope?
Another approach is to use a fast transistor or fet as a buffer.
Re: Pulse generator
Sounds good to me. You have to remember that I am not an EE. How about posting a schematic for a device that works.
Tom Dressel
Tom Dressel
Re: Pulse generator
Tom - I do agree with Jim Lux... the 741 is too slow for your purposes. But since the 555 puts out several volt square waves, why not just feed the output through a capacitor in series with either a 50 or 75 ohm resistor to ground. The take your output from across the resistor and use a voltage divider to get the level you need.
Regarding noise.... check that your DC Pwr supply has high frequency caps on the output side. Especially necessary if its a bipolar supply (+/- voltages), since the negative linear regulators are notorious for self oscillation. But...... is your power supply possilby a switcher? If so.. that's likely to be the source of your noise.
One solution to this is to build a good filter for the supply output...needs an inductor in series and a capactor to gnd. This will block any current pulses from your 555 from getting into the supply.
Use your oscilloscope set to AC coupling and look at your DC PS with and without the 555 circuit load. If all is well, it is not unreasonable to expect the output to be clean at least to 1.0 mv with 5 to 10 volts DC set.
Re: Pulse generator
Thanks for the advice.
I am using a 7815 voltage regulator, with a 0.1 uf cap across the output to ground, to drive the 555 chip. (15 volts to ground). The op amp is driven by the 7815 and a 7915, voltage regulator again with a filter cap on the output (+15 volts to -15 volts). Possably one or both of the filter caps are bad.
Anyway, I think for starters, I will use the square wave calabration from the scope to drive the cap-resistor combo as you have suggested. I am not trying to get fancy I just need some fast pulses to set up the NIM components.
Tom Dressel
Tom Dressel
Re: Pulse generator
Tom -
I think using the calibration signal will be pretty simple to use. Depending on the age of your scope, the rise time will either be TTL compatible (50 nS rise time) or slower. The RC, (cap input, resistor to gnd) circuit forms a nice, simple differentiator, giving a pulse width approximately equal to the risetime of the square wave.
Regarding your present circuit, the 741 is a bit too slow, as we mentioned before, but the caps on your 7815 and 7915 's could be okay, just need some more capacity. The 7915 needs a 1 mfd solid Tantalum on the output, in parallel with the typically 10 or more ufd output electrolytics to keep it stable. I usually do the same thing for the positive regulator, too.
Wiil be interested to hear how it goes.
Re: Pulse generator
Bipolar 555s are notorious for injecting trash into supply lines due to cross conduction in the output driver stage. Any of the CMOS 555s will be much better in this regard. The later CMOS 555s such as the TI TLC555 and the National LMC555 also have much faster edges than the bipolar device. Radio Shack may even have the TLC555. If not, it can be found easily from a supplier on the Web.
Follow the output of the TLC555 with a RC differentiator, then use a capacitor coupled emitter follower circuit to buffer the differentiator. This can then be coupled to an attenuator, and followed by another buffer. A simple bipolar emitter follower will beat the pants off of a 741 for speed any day of the week. If you are willing to deal with just one polarity of pulse, the resulting circuitry can be pretty simple, and capable of being powered by a 9V battery.
Re: Pulse generator
Thanks again.
Everything I know about electronics I got from Forrest Mins handbook on IC chips.
I should be able to try some of the suggested fixes this weekend.
Tom Dressel
Tom Dressel
Re: Pulse generator
I picked up a low power TLC555 timer chip today, which should help with the noise problem. But I also found a Tectronix type 115 pulse generator at a salvage place for $20.00, (See IDJ post), which definitely solves the noise problem. Attached is a tracing of a clean 50 nsec. pulse.
Tom Dressel
Tom Dressel
Re: Pulse generator
SURPLUS IS THE WAY TO GO. I have always said this and hamfests and surplus outlets can supply material and devices that we could not dream of replicating with any ease or functionality.
Sometimes we are fored to cobble something up due to time constraints or due to the fact that it just doesn't exist in nature. Pulse generators are not one of those items.
Tektronix, HP, GenRad (General Radio) and IEC (Industrial Electronics Corp) are among the best pulse generators I have seen and used.
