I have spent the last few days working on a single width NIM module design which will effectively be an audio and visual ouput device for a number of detector systems.
I had to design the electronics around commonly conditioned NIM type signals. The signals are usually fast rise time, short duration, positive pulses of a few volts. I decided I would also want the system to respond to signals as small as 50mv or so. I designed an input stage around a simple single transistor design (2N2222) which includes a sort of sensitivity adjust pot.
The signal is then shaped up by a CMOS 4049 buffer and presented to a variable delay monostable (555). This then puts out a time stretched positive 12 volt pulse which is ground referenced.
I use one of those totally annoying sonalerts controlled by the pulse width control in the 555 circut. (~2ms to 1 second in three ranges.) This then just chirps based on the on-time pulse width. The reason for the long widths is for extremely infrequent pulses as in neutron background counting. I found that my BF3 units short audio out pulses could be missed coming so infrequently. A 0.5 second blast from a sonalert will signal a detection event that will not be missed in the next room, even! As a blessed, saving grace, I am putting a toggle switch on the sonalert to mute the device and preserve sanity over the long haul.
I added a 10,000 mcd green led as a visual indicator. The light is diffused by mounting the LED in a short legth of hot melt LDPE which mounts to the front panel.
I bread boarded the circuit last nite, debugged it and will assemble the device later this week or next.
I have a couple of more personalized NIM modules planned in the future. I have several older, blown up modules which I gutted to use as shells for this effort.
Rolling my own NIM module
Jump to
- Announcements
- ↳ Announcements and Site Administration Topics
- ↳ The Fusioneers
- Start Here
- ↳ Frequently Asked Questions (FAQs)
- The WaterStar Project: Finding the Trailhead
- ↳ Philo T Farnsworth Archive
- Images and long term fusor.net contributors
- ↳ Images du Jour
- ↳ Compilations of long term fusor.net technical contributors
- Theory
- ↳ Fusor and/or General Fusion Theory (& FAQs)
- ↳ FAQs: Fusion and Fusor Theory
- ↳ Other Forms of Fusion - Theory, Construction, Discussion, URLs
- Construction / Technical Do not post simple questions here. Use the New User Chat area
- ↳ Fusor Construction & Operation (& FAQs)
- ↳ FAQs: Fusor Construction & Operation
- ↳ Vacuum Technology (& FAQs)
- ↳ FAQs: Vacuum Technology
- ↳ High Voltage - Fusor Input Power (& FAQs)
- ↳ FAQs: High Voltage
- ↳ Neutrons, Radiation, and Detection (& FAQs)
- ↳ FAQs: Neutron - Radiation Detection
- ↳ Ion Gun Design and Construction (& FAQs)
- ↳ FAQs: Ion Gun Design and Construction
- ↳ Control and Instrumentation Hardware and Software
- ↳ Advanced Technical Discussion Area
- Miscellaneous
- ↳ Fusion --- Past, Present, and Future
- ↳ Interesting Links
- ↳ Files
- ↳ Books & References
- The Trading Post
- ↳ Primary Sources for Fusor Related Items
- ↳ Items For Sale
- ↳ Items wanted
- The early beginnings of fusor.net
- ↳ Songs Archive
- ↳ Intranets Archive
- Archived Old Announcements
