Signal Processing Tutorials
Posted: Thu Jul 05, 2001 7:55 pm
by guest
Those wishing to design their own signal processing electronics for nuclear detectors might do well to steal over to
www.physics.lbl.gov/~spieler, and do some heavy downloading. Contained there are some exquisitely detailed lecture notes in *.pdf format expounding on detectors and signal processing techniques for nuclear instrumentation. Spieler doesn't get into any real down and dirty circuit design details, but you definitely get some good ideas as to the direction you should be going, as well as how to avoid some common troubles regarding grounding and shielding.
Re: Signal Processing Tutorials
Posted: Fri Jul 06, 2001 5:45 am
by guest
Thanks for the heads up Richard, it's exactly the kind of info I'm after at the moment.
Posted: Sat Jul 07, 2001 2:07 am
by guest
Hi Richard, Is that url correct?? I'm having trouble accessing it
Posted: Sat Jul 07, 2001 2:11 am
by guest
I did find it after changing
to www-physics.lbl.gov/~spieler/
Posted: Sat Jul 07, 2001 5:24 pm
by guest
Ahem, yes - my bad. I'll look closer next time. However, I think you'll find that the information was worth the hunt. That's www-physics.lbl.gov/~spieler/, for everyone else. The prize is a 190-odd page set of course notes in pdf format on signal processing for nuclear instrumentation. It's a 3Meg+ download...
