Signal Processing Tutorials
guest
Post by guest » Thu Jul 05, 2001 11:55 pm
Those wishing to design their own signal processing electronics for nuclear detectors might do well to steal over to www.physics.lbl.gov/~spieler, and do some heavy downloading. Contained there are some exquisitely detailed lecture notes in *.pdf format expounding on detectors and signal processing techniques for nuclear instrumentation. Spieler doesn't get into any real down and dirty circuit design details, but you definitely get some good ideas as to the direction you should be going, as well as how to avoid some common troubles regarding grounding and shielding.
guest
Re: Signal Processing Tutorials
Post by guest » Fri Jul 06, 2001 9:45 am
Thanks for the heads up Richard, it's exactly the kind of info I'm after at the moment.
guest
Post by guest » Sat Jul 07, 2001 6:07 am
Hi Richard, Is that url correct?? I'm having trouble accessing it
guest
Post by guest » Sat Jul 07, 2001 6:11 am
I did find it after changing www.physics.lbl.gov/~spieler
to www-physics.lbl.gov/~spieler/
guest
Post by guest » Sat Jul 07, 2001 9:24 pm
Ahem, yes - my bad. I'll look closer next time. However, I think you'll find that the information was worth the hunt. That's www-physics.lbl.gov/~spieler/, for everyone else. The prize is a 190-odd page set of course notes in pdf format on signal processing for nuclear instrumentation. It's a 3Meg+ download...
