Previous work from Carl Willis and myself…
viewtopic.php?f=13&t=5846&p=38723&hilit=uranium#p38723
viewtopic.php?f=13&t=5860&p=34304&hilit=uranium#p34304
As expected, this latest attempt turned up the anticipated 74 KeV gamma from U-239. But what also turned up (completely unexpected) were several short-lived fission products. Amongst those short-lived fission products were what Carl suspected he was seeing, 15.2-minute Rb-89. Wow, fantastic work on Carl’s part.
Activation specifics: 5.788 grams of Carl’s ammonium diuranate (yellowcake) was baked in the neutron oven for one-hour at 7.0E+06 n/s TIER. This was the first time I had run the water-cooled cube fusor that long and that hard. (55 to 56 kV at around 9 mA) TIER at the start of the one-hour run was 7.1E+06 n/s at a temperature of 34 C. At the end of the run TIER had dropped to 6.9E+06 n/s and temperature had crept up to 41 C. After activation the yellowcake was transferred to my hpGe spectrometer for a 3000 s count. (For comparison purposes a 3000 s “background” count was done just prior to activation.
Jon Rosenstiel
Neutron Activation of Uranium (Redux)
- Real name: Jon Rosenstiel
- Spectra, expanded.pdf
- Figured some may like to see a little more detail.
- (514.53 KiB) Downloaded 21 times
I like old-timey heavy electronics that you don't have to hold down
with one hand while pushing the on/off button with the other.
- Mark Rowley
- Real name: Mark Rowley
Re: Neutron Activation of Uranium (Redux)
Absolutely fantastic work Jon. And the 1hr run at such a high output level has to be a record on its own.
Regarding the gamma spec, are any of those telltale peaks something that would show on a NaI(TI) based system?
I was really impressed at how stable she ran. I did minutely readjust the throttle valve a few times during the run, mainly because I didn’t want the hv to creep up the slightest... have already gone through too many feedthroughs. I have some quartz tubing, one of these days I’m going to try my hand at constructing the David feedthrough.
Seems like this would be pretty tough to do on a NaI detector.
JonR
JonR
Jon , the "pace setter", ever out in front. Fabulous work Jon! My jaw dropped as I read the details on the run and marveled at your gamma spec. You pack the gear to do this and I will add this to your Elite Fusioneer blurb. Wish I coulda' been there swilling a strong root beer watching the long run and musing with you as you minded the controls. Excellent work.....As I say all too often..."you be da' man!"
You are correct with that crowded spectrum and smaller peaks for the fission products, an NaI spectrum would have had a couple of bumps in places combining all the fission products. The few dollars and the hassle you spent on the LN2 to get that spectrum was money and time very well spent.
