Schematics for Spectech ST-360
Re: Schematics for Spectech ST-360
Post by Dennis P Brown » Sun Mar 12, 2017 5:52 pm
Well, one leg of the diode chip is bad (reads open for a fraction of a second then starts to conduct and show a 0.7 volt when it should read open.) So, if the diode took a hit, then it is very likely U-15 is bad (just received new U-15 chips but the diodes will be awhile before they arrive.)
The photo-multiplier does not detect neutrons significantly above the noise so, it isn't suitable.
The water cooling of my fusor chamber works great and keeps it fairly cool!
Post by Dennis P Brown » Wed Mar 15, 2017 2:35 pm
Replaced the diode voltage clamp (micro-soldering while work under a microscope!) and the ST-360 works well with a scintillation detector (through, maybe a bit more noisy now.)
However, can't get it to work with my neutron tube - while I have a cap between the ST-360 (built into the voltage divider) and the applied power for the neutron tube (the voltage divider lowers the total voltage the ST-360 cap see's to around 1200 volts) my ST-360 signals a system failure when I go above 1750 volts on the neutron tube.
Will have to do more work to see if it is tube related or the ST-360.
