Possible replacement for my now partly failed ST-360 Counter
Re: Possible replacement for my now partly failed ST-360 Cou
Post by Richard Hull » Fri Mar 03, 2017 3:52 pm
GM tubes, typically, need no amplification whatsoever in an electronic GM counter. Some counters do pulse shaping/forming or invert the pulse, but the signal directly from a GM tube is measured in volts or tens of volts!
Circuit digrams are best posted in the radiation forum for radiation instruments.
Post by Dennis P Brown » Sat Mar 04, 2017 5:44 pm
Thank you Richard.
Did not know about GM tube signals (nice to know that); makes sense how the ST-360 handles that signal. Petty much confirms were my problem is; the U15 chip is easy to obtain. I will add that their sub-circuit for detecting a GM or scintillation signal is an ideal pre-amp/amp and voltage comparator system. Since I am ordering the Op-amp chip (with spares), I guess I will order all the components (other chip, resisters and caps) and copy that nice system for future projects. Saves me a great deal of time and trouble trying to balance a chip/feed-back circuit system for where a BF3, GM, and scintillation tube all like to operate! Would be easy to add a counter to that final chain. Might consider building a neutron/scintillation detector system for fun, electronic training/practice and of course, use with the fusor. But first, get he ST-360 fully working again.
Having the schematic was handy for not just understanding that sub-circuit but following it through its entire path until data display - the main special monster chip plays only a minor role (and is of no importance for the detection and counter display.) Again, good to know.
I will post the circuit later this week.
Aside: my DP pump has a heater problem; this forced me to break my system down so I can get at the heater section. Does give me an opportunity to add water cooling to the main chamber, and do a few changes/mods to make it a bit better. I am running into a host of issues since my neutron success - worst, they were all caused by me pushing my system too hard ... .
