RF ion source, modified, with deuterium
Carl Willis
Real name: Carl Willis
Post by Carl Willis » Tue Oct 21, 2008 6:00 am
My original RF ion source was described here:
viewtopic.php?f=12&t=5006#p32314
It used a $100 glass-to-metal adapter as the discharge bottle, a capillary gas feed, and previously was only operated with air.
In the newer version, the glass-metal adapter is replaced with a $1, standard 19mm test tube, feeding the gas into the extraction gap via the anode flange as shown below in the drawing. To suit the very low discharge pressures favored by this source, I have cut down on gas flow considerably by adding a 4 micron laser-drilled septum purchased for $40 from Lenox Laser in the gas feed circuit. Also, although not shown in the drawing, I have placed a #8 ceramic washer (Small Parts, Inc.) over the extraction aperture to help shield the exposed copper in that region. Copper is good at recombining the atomic ions we want out of such a source and it should be shielded as much as possible.
The attached photos show the ion source operating in D2 gas, about 0.5 sccm, producing about 200 uA of current. I closed the throttle valve some so that the residual pressure is up around 10 millitorr and the beam is nicely visible in the gas. It has the characteristic red color of clean deuterium beams (contrast with the pale blue from an air beam in the previous thread), although the discharge in the bottle is a similar shade of pale grayish-pink. When the target is biased at -15 kV, some neutrons can be detected by a small He-3 tube (maybe a dozen CPM). I cannot run the feedthrough above 15 kV without putting it in oil, something I might do just for the heck of it to make more neutrons.
Carl Willis
TEL: +1-505-412-3277
Re: RF ion source, modified, with deuterium
Post by Steven Sesselmann » Tue Oct 21, 2008 6:33 am
Nice work Carl, the source looks real bright.
How much power does the RF draw?
Could the 200 uA include secondary electrons knocked out of the target?
Post by John Futter » Tue Oct 21, 2008 6:49 am
Carl
nice pic of beam in the view port
reminds me of the testing when we test the ion source on the 3MV machine with the tank off (acceleration tube shorted out) testing the H2, D2 , He beams before putting the tank on and filling with insulating gas.
I see you are using permanet magnets
have you thought of using a solenoid type coil to tune the plasma for your particular operational conditions??
John
honickmonster
Post by honickmonster » Tue Oct 21, 2008 1:10 pm
Very nice work. I was wondering, at what voltage you were running the extractor?
Matthew
Post by Richard Hull » Tue Oct 21, 2008 1:29 pm
Most fascinating work done on the ion gun front. Can we expect to see multi-gunned fusors in the amateur community in a couple of years? That would be just too cool.
Carl has done a nice piece of homebrew engineering here. That's worth several atta' boys, at least. Nice to see this front moving out a bit.
Kelson
Post by Kelson » Tue Oct 21, 2008 6:03 pm
I love the switch from the $100 to $1 piece. That made my day. Beautiful pictures, as well.
DaveC
Post by DaveC » Tue Oct 21, 2008 7:26 pm
Carl -
Nice, continuing work. Thanks for the pictures and cross-section drawing - a good clean design.
Do you have any ideas as to what the current density distribution might be across the extractor diameter: possibly gaussian, or uniform up to the walls, or something else, etc?? Any plans to measure it?
Carl Willis
Post by Carl Willis » Tue Oct 21, 2008 10:04 pm
Hi John,
Some similar ion sources have been built (George Miley's "ILLIBS" for instance) using solenoid electromagnets to enhance the discharge and / or focus the beam in the extraction region. The thought has occurred to me, and may be an issue I explore later on. For now, I use a ring of rare-earth magnets that can be moved pretty easily. There are indeed positions of these magnets that greatly increase extraction current. A combination of permanent magnets with electrical shimming magnets may be the ideal approach.
Matthew, the extraction voltage was -2900V here.
Carl Willis
Carl Willis
Post by Carl Willis » Tue Oct 21, 2008 10:29 pm
Hi Steven,
The RF here is 50W forward power. There are probably a couple dB of loss due to radiation resistance, heating up of the RG-233 lead, and various other factors, but this is basically a 50W discharge.
I've taken some precautions to limit the contribution of secondary electrons to the current measurement. The target is a cylinder of graphite that has a blind hole drilled in it where the beam enters it. This should geometrically restrict the escape of most electrons. Of course, I have no good way of telling quantitatively how effective this is.
Carl Willis
Carl Willis
Re: RF ion source, modified, with deuterium (a couple "glassblowing" pics)
Post by Carl Willis » Fri Nov 07, 2008 7:00 am
I replaced my $1 test tube and ceramic-washer anti-sputtering shield with a single piece of glass. The new glass may not be $1 anymore, but it is still a bargain compared to glass-metal adapters. Now the discharge "bottle" is butt-sealed to another piece of 19-mm tubing with a flat closure (made by blowing a hot, thin closed end of tubing into a graphite paddle); and a little hole, slightly smaller than the anode extraction hole, is blown in the seal so that ions can be extracted. No metal is directly exposed to the discharge anymore, and the ion source can be operated in any orientation.
Photos show my primitive glassblowing equipment and a completed discharge bottle so that others may get some ideas. Being that I am not a human lathe, I can't rely on my hands alone to keep two glass tubes coaxial while rotating them and translating them at the same time, so we see the little fixture I made to accomplish this task. The two pieces of tubing are brought together in the jig while rotating in the torch flame, and the springs keep enough restraint on the tubing to keep it coaxial. A finished ion source bottle can be seen on the fixture.
A couple asides now. The best way to cut Pyrex tubing of this size and larger (I have tried many methods!): make a deep but short score mark on the tubing with a carbide knife-sharpener. Wet the score and continue drawing a bit of water about half-way around the circumference of the tube; this is important. Bring a tiny, ultra-hot flame, such as from the #1 tip for this National blowpipe, into brief tangential contact with the tubing a few mm ahead of the score on the DRY half of the tube. The tube will cleanly crack circumferentially on the WETTED side. Finish the job with a gentle tug.
My glassworking torch uses propane from a small $2 bottle (lasts many hours) and oxygen from a 5 LPM medical oxygen concentrator. These concentrators are fascinating but conceptually simple pieces of hardware that exploit the unique affinity of nitrogen for molecular sieve beds. Nitrogen is separated from the air, leaving oxygen and other trace gases. The torch loves it just fine, and you don't have to deal with the expense and nuisance of big gas cylinders.
Thanks to Mike Donovan and local pro glassblower Dean Horinek for their helpful advice on this new skill I'm figuring out.
Carl Willis
