Neutron gun...
TheTim
Neutron gun...
Post by TheTim » Wed Apr 04, 2007 1:11 am
I understand the basic principles of ion/electron gun function...I'm curious to know if it's possible to create a directional neutron gun. I don't mean making an omni-direction neutron generator and blocking it all the way around except for a small opening...That's not exactly directional...
Obviously neutrons lack charge, so I would assume differentially polarized electric or magnetic fields would do absolutely nothing.
Carl Willis
Real name: Carl Willis
Re: Neutron gun...
Post by Carl Willis » Wed Apr 04, 2007 1:57 am
Hi Timothy
Getting highly directional neutrons is possible via kinematic constraint in the reaction used to produce the neutrons. Consider an endothermic reaction like Li-7(p,n)Be-7, whose threshold is about 1.8 MeV. If you carry out this reaction with a beam of protons incident on a piece of lithium right at 1.8 MeV, momentum and energy can only be simultaneously conserved if the neutron is expelled into a very small forward-directed angle. The cost of using this method to make a beam of neutrons is the low efficiency. Almost all of the proton beam energy is wasted heating the target. Any other similar threshold (X,n) reaction could be used in a similar manner.
Carl Willis
TEL: +1-505-412-3277
Re: Neutron gun...
Post by Richard Hull » Wed Apr 04, 2007 5:37 pm
Carl beat me to the Li+P reaction, which is classic for neutrons in the forward direction. There are others as Carl notes.
The cost of such a very inefficent source would be in the $50,000 range with new stuff used. Getting the proton beam up to 1.8 mev + at a sufficient beam current to be effective would be the real cost here.
Got big bucks? You can have a tolerable beam of neutrons all within the confines of a small 8X12 foot room full of gear, complete with leathal x-ray radiation and other sprays of EM radiation.
Looking for a cheap beam? You are back to blocking off a small section of an isotropic source operated at low cost.
Again, all hinges on your desired beam energy or desired flux.
