Ports for ion guns
Re: Ports for ion guns
Thank you all very much for the help. Below is a sketch of my plan. Will the location of the ports work with future ion guns?
Yes, this looks oK if two guns are your goal.
Thanks to Brian for catching the error on the calcs. I was still locked in D-D mode.......As are we all.
D-T makes a big difference don't it!
- Brian McDermott
Specifically, what trouble did he run into?
Perhaps this should be in a new thread?
Joe found that the filament and ionizer system really performed too well and the main fusor acceleration current was seen to suddenly spike. The ionizer system current had a more far reaching effect on accelerator current to the point that the ionizer system had to be run at vey low levels that were tough to control. All of this made the pressure much more critical to control, as well. Lots of variables. perhaps too many for manual control. The only way to evaluate is to actually do it oneself, I figure.
I sort of wished Joe had reported on this personally, but he was not much for online interaction then.
- Brian McDermott
Just to correct those calculations a bit:
I recall you saying that Hirsch's 10^12 machine ran on D-T fuel. If that is the case, every neutron signifies one fusion, and each fusion releases 17MeV. (The original calcs assumed D-D fusion.)
So the calculation ought to be:
10e12 (total fusions=the number of neutrons) X ~1.7X10e7 (average eV/fusion) X 1.6X10e-19 (joules/eV) = 27.2 joules or 27.2 watt-second
When he achieved these results, what were the voltage and current being used? Assuming the total input power was between 1 and 10 kilowatts, this is (relatively) much closer to breakeven than the typical 7-10 orders of magnitude.
I also posted this in the construction/operation forum, since this topic is no longer pertinent to the original thread.
