Although not an ion gun per say...plasma gun.
apollo
Re: Although not an ion gun per say...plasma gun.
Post by apollo » Sat Jun 19, 2004 1:16 am
Hi there
You made reference to a wire suspended 1/2" below the arc. Did you forget this on your diagram? Also, how many volts should it be, and wouldn't it be more efficient to use one or two good magnets, positive side up?
-Liam Bowen
3l
Post by 3l » Sat Jun 19, 2004 1:40 am
Hi Liam:
That wire creates a mirror magnetic field that does the actual repulsion. To get a really good result the discharge voltage should be at least 2kv.
Happy Fusoring!
Larry Leins
Fusor tech
dmills
Post by dmills » Mon Jul 05, 2004 12:55 am
Sounds like a job for a Compulsator (compensated pulsed
alternator). These also look kind of cool for a Z pinch rig.
Serious current pulses from stored kinetic energy!
Just remember the reaction torque on the stator when the thing
is triggered!
http://www.utexas.edu/research/cem/prog ... ed_ac.html
Just dreaming!
Regards, Dan.
gopher
Post by gopher » Fri Nov 19, 2004 5:12 am
So... has anyone yet constructed this device (besides Mr. Leins)? If so, please share the results!
Q
Post by Q » Sat Nov 20, 2004 12:04 am
i did, but i was not successful. i kept having mechanical issues with the carbon electrodes... i couldn't find a way to keep them secure. so, i got some nice arcs, but every time i discharged the cap, the electrodes would be blown out of the device.
i donno, is a .15uf 35kv cap to big?
Q
3l
Post by 3l » Sat Nov 20, 2004 2:31 am
Hi Q:
I would start smaller than that value capacitor.
To hold the electrodes really tight curtain tube rods work well.
Ive even used arc welding electrodes firmly mounted.
When using rod make a "v" with the two rods just like a jacobs ladder but space them so the arc stays put.
This way the recoil is less on the electrodes and the plasma flies away fast and hard.
Happy Fusoring!
Larry Leins
Fusor Tech
Q
Post by Q » Sat Nov 20, 2004 4:41 am
thanks, larry!
i have been re-planning this expiriment... think i'll go down to a nice 90j cap instead. i'll also be using larger electrodes; the 3/16" carbon rod i was using seemed to detonate at the power level i was using. poor planning on my part.
Q
charlie_mccartney
Real name: Charlie McCartney
Post by charlie_mccartney » Fri Mar 21, 2014 4:44 am
I know this topic has been dead for a long time but what ever happened? Does anyone have any pictures or videos of one of these?
Charlie McCartney
charlie.mccartney1104@gmail.com
charliespersonalproject.weebly.com
Post by Richard Hull » Fri Mar 21, 2014 7:41 pm
This whole thread risks deletion! This is not a fusion usable ion gun and therefore is under consideration for deletion. I'll give a day or so and all the thread is probably gone. Fusion related guys and fusion only. This is not a fireball cannon DIY site.
