Custom o-ring seals are doing great. Deepest vacuum with the Yellowjacket pump has been 7mTorr which means a secondary diffusion pump would bottom this out to sub-milliTorr levels with ease.
9mTorr is after about a minute of pumping time.
Later today will be a stress test of the viton o-rings under heated conditions. Fairly sure I’ll be needing a longer quartz tube.
Here’s the tube furnace which will be incorporated with the setup. Operational temps will be roughly 900 Celsius. My concern with this arrangement is it’s considerably slower cool down time. A redesign allowing for an immediate drop-down arrangement may be required.
Apparatus for Making a Deuterated Target
- Mark Rowley
- Real name: Mark Rowley
- Mark Rowley
Re: Apparatus for Making a Deuterated Target
So far a surprising success. The o-ring areas remained very cool with forced air blowing over the heat dissipators. Even at 900 Celsius neither o-ring area exceeded 35 Celsius (95F)… even after several hours.
Shown here is the back side of the furnace with forced air blowing over the dissipators. The glowing red alumina heating element can easily been seen in this shot.
This is a comparison between a treated and untreated piece of titanium sheet.
Being a first attempt, the system was gently operating at a reduced duty cycle. The titanium was only maintained at 900 Celsius for just under 2hrs. 100mL of deuterium was not enough to bring the chamber up to 1 atm, but it got fairly close. In the future I’ll use a 150mL reservoir and push the heating duration closer to 3 or 4hrs.
As of now the next step is to install the treated titanium in the fusor.
This is fabulous stuff! You really lay it out with a great balance of plenty of images and explanatory text. I remain amazed at your doggedly pursuing the issues that interest you and those of us witnessing your many and continued efforts. A shining example of open source sharing.
You note the 7mtorr yellow jacket number. That is what I got at my best with my old yellow jacket pump on fusor II and III. For a well kept refrigeration pump they are rather fantastic. One of the few I ever had that performed on a par with a good welch belt drive, (which I consider the gold standard).
- Mark Rowley
Thanks Richard. It’s a definitely a fun pastime, and yes.. the Yellowjacket is a great pump. Thanks again for the recommendation! It must’ve been around 2002 or so.
RESULTS
I decided to install the titanium in the fusor by using a slide-in aluminum sleeve. Even though the fusor is water cooled, I expected this to heat up rather quickly causing the typical associated issues. There’s just no way to firmly attach the titanium to the cooled fusor wall without extensive machining.
So today’s run provided promising yet inconclusive results.
For a freshly opened chamber and subsequent pump down, the fusor instantly yielded a TIER of about 5.4E+5 n/s at 55kV / 0.3mA!! Never before have I seen those numbers at such low current and within seconds of switching on the power.
So here’s where it became expectedly troublesome. As I ramped up the voltage and subsequent current, it began to plateau just under 2E+6 n/s. Increasing the voltage any further resulted in a diminished neutron yield. This was not the case under normal conditions as any increase of voltage resulted in considerably more neuts. It’s fairly clear target heating was poisoning the conditions within the fusor. It’s somewhat reminiscent of how things behaved before cooling was added to the design.
So where to go from here? Well, I still have some unrelated projects to complete with Fusor2020 so I’ll remove the titanium target and restore it to normal operating conditions. Once done with the other projects (psu modification and Maciek’s track detectors), Ill make some new deuterated target material and install it in the BoT for testing. Afterwards, a cube fusor may be in the works. Seems like it’d be easy to make water cooled endcaps where titanium targets could be firmly secured to their respective chamber sides. A cylindrical grid would be used to create opposing deuteron beams to hit each deuterated target (similar to Jon’s titanium coated endcap design. Definitely no shortage of projects for the foreseeable future!
RESULTS
Truly a great effort, fantastic equipment builds, and excellent reporting.
I am not sure this would be a good idea but electrically conductive silver epoxy would readily hold the Ti strip to the chamber wall and maintain the strip at wall temperature, of course. But you'd end up with silver on the walls if you removed the Ti strip. But it would readily hold the strip even under vacuum (I've used the stuff to mount targets in a sputtering system.)
- Mark Rowley
Thanks for the kind remarks Dennis
For a multitude of reasons the fusor has been completely disassembled and probably wont be fired back up again for quite some time. However, when some domestic renovation projects are complete the plan is to go 110% into beam on target systems. The aforementioned results at 0.3mA with a deuterated target make it blazingly clear which system will provide a more substantial neutron yield. As with Richard, I've only viewed the fusor as a source of neutrons for activation experiments. As done in the past, it's really fun meshing this hobby with gamma spectroscopy. With the fusor I just started to tickle molybdnum for TC99m before I reached the capacity of the psu. But with the 0.3mA observation, BoT systems with a deuterated target and relatively simplistic PSU hold high promise for activations beyond Molybdenum.
Like a classic 1950's BoT system, the Fusor too is just a different form of neutron generator, not a fusion energy device that holds promise to generate electricity. The deuterated target was impressive enough that retooling and moving forward towards a water cooled BoT is the only way to go, at least from this stage. It's not a project I'd recommend to anyone new in the Fusor hobby as just about everything has to be custom made.
Very wise words regarding the complexity and required skills to follow your path, Mark. I liked your admission related to using the fusor as a neutron source for activation. Ever since I was in college I wanted to do activation experiments. In college at 18 I already had 5 years of monkeying with radiation and various isotopes supplied by Abbott labs in Oak ridge. You could get those in chemical form back then. Neutrons are jealously held by all atoms and it takes a bit of doing to get enough to really experiment with activation.
