Very, very nice work Andrew. This shows "where there is a will, there is a way"! Onward and upward.
Spellman -40kV PTV power supply
Re: Spellman -40kV PTV power supply
- Real name: Andrew Seltzman
Annotated schematic with modifications:
Andrew Seltzman
www.rtftechnologies.org
As advised by Cliff, I have added a blower to keep the HV transformer secondary cool. It is a 12v blower and is fairly high performance generating significant airflow over the winding. The power supply is designed for a 24v fan so a DC-DC converter is used to convert the voltage to 12v.
12v DC blower Standoff added to power supply 12v DC blower mounted on standoff and aimed over transformer winding, DC buck converter converts 30V from supply to 12V for the fan
Andrew Seltzman
Drawing power from the 24V port was found to cause a voltage spike of shutdown(even though this is where fan power was supposed to come from). Instead an AC-DC power brick was connected to the internal corecom inlet filter to supply power to the fan, solving the HV spike problem
Andrew Seltzman
- Garrett Young
- Real name: Garrett Young
Another question for Cliff ...
Is there any headroom on the voltage multiplier section? Can the PTV30N be run at 31 or 32 output kV with feedback modification?
- Garrett
