Anyone have any opinions on how suitable this NST is for Star Mode.?
http://cgi.ebay.com/NEON-TRANSFORMER-15 ... 2a0e59922c
Power Supply NST...
- Real name: David D. Speck MD
Re: Power Supply NST...
The NST you indicate has a GFI (Ground fault interrupter) circuit. That's good for neon signs, but not so good for non-standard applications like a fusor. You will probably have fewer frustrations with the Non-GFI version.
Same seller has non-GFI transformers, same rating, same money. I'd go for one of those.
Be sure to read the FAQs about NSTs. NSTs may work for a demo fusor, but you will not be able to produce significant fusion with one.
Dave
Dave
for example this one
http://cgi.ebay.com/NEON-TRANSFORMER-TE ... 2a0e59635c
That may be a better choice that the first unit suggested.
I will have to defer to other list members as to whether you are likely to get a star with this NST.
Check the FAQs to see if you can get a Star with a NST.
Dave
Dave
Star mode can be easily obtained with a floating 15kv 60ma neon sign transformer using a high voltage bridge. Note *** this makes the transformer case dangerous,(floating at high voltage), therefore it should be in a wooden box and covered at all times.
The key to star mode is a clean vacuum with an air pressure of about 4-10 microns.
The higher the applied voltage, the cleaner and more distinct the star, but rarely is more than 15kv needed. Good stars can be had at 10-12kv in a well managed vacuum.
i thought u said in ur faq tht 40 -50 microns is good for demo? also does this mean tht with a two stage rotary vane pump a diffusion pump is also needed?
Most two stage rotary pumps, if working well, will easily get you down below 20 microns. Demo fusors work well from 100 microns down to extinction near 5 microns.
The most beautiful stars are produced and seen at pressures below 20 microns. You do not normally need a diffusion pump to get a star in a demo fusor. Just make sure you get a good mechanical pump and you should be OK.
