Current and Voltage Metering for a HV Supply
userjjb
Post by userjjb » Fri Apr 11, 2008 2:28 am
I know this has been covered several times but I'm unclear on a couple things...
See the diagram below (we are using a bridge rectification setup with the positive output from the bridge grounded because our transformer doesn't have a center tap)
Will a DMM in series with the grounded positive terminal from the bridge rectifier read the proper current? I've seen current shunts mentioned, but am hazy on what exactly these are/do/consist of?
I've also seen a need for current limiting mentioned, currently we have none. I've seen both inductive ballasts (MOTs or NSTs with shorted secondaries and the primaries in series) and resistive ballasts (1 ohm per volt or thereabouts?) mentioned. Which current limiting method is better, or should both be used in conjunction?
Finally how should voltage output be measured? I've seen voltage dividers mentioned and after some research think the scheme drawn in the diagram is appropriate. The DMM put in parallel with R2 should read R2/R1 fraction of the output voltage, correct? What values are appropriate for R2 and R1? I've seen ratios of 1000:1 cited so the DMM will read in kV, but what about actual values for R1? I'd imagine R1 should be sufficiently high so it doesn't divert an appreciable amount of current, but not infeasibly high.
Thanks,
-Josh
Edit: I originally and erroneously showed the MOT ballast as being after the HV transformer in the diagram which of course is wrong, a little editing in paint fixed this.
fusor schematic.JPG (42.81 KiB) Viewed 2183 times
DaveC
Re: Current and Voltage Metering for a HV Supply
Post by DaveC » Fri Apr 11, 2008 7:42 am
Josh -
Your circuit looks good to me... except that your ballast... (the MOT) should connected with the SECONDARY in series with HV... it's the winding that has the insulation for HV, with the primary shorted... or better with some resistance across it.
[ Edit: - You edit fixed it. Looks good, now.!!]
The voltage divider ratio of 1000:1 is very conventient. The design aspect of the divider is simply how much current you it to draw. The Divider circuit typically should not take more than a few percent of the HVDC output... so a 20 kV 10mA supply (puts out 200 watts) could use a divider string that consumes maybe 4 watts. Using the formula P = V^2/R, gives a nominal R around 100 Meg Ohms...
For a 1000:1 ratio, near this value, with a 10 Mohm input DMM., you could use a 95 M Ohm string for your R1 and a 10 M ohm resistor for R2 (shunted with the meter's 10 M ohms input iresistance). The 95 M Ohm string.. could be 9 10 meg resistors or 18 - 5 meg resistors plus a 5 M ohm resistor in a little bit of perf board. Most carbon or metal film resistors can;t be used at such high voltages, as a single element.. and finding very high values resistors takes to just a few mfrs. and they get pricey and long delivery times. So stringing them together can save you some money and time.
This kind of divider, assembly CAN operate in air at up to about 20 kV if you build it with enough spacing and nice smooth solder ball type joints. It works a lot better in oil, though. Use 1% resistors and you will have a system that's as accurate as any commercial HV divider.
When you get if working, you can also check for ripple levels, by just switching your meter to AC. If the ripple voltage is more than about 10% of the DC, put a 1uf 50 V polyester film cap across R2 for some filtering.
Just be careful... HV can bite!
userjjb
Post by userjjb » Fri Apr 11, 2008 10:46 am
Thanks a lot Dave! Up until now we've been pretty sparse in the way of instrumentation as far as output power goes. Flying by the seat of your pants when it comes to HV is never a good idea. We do have an electrostatic voltmeter that reads up to 20 kV, unfortunately it only reads positive so the only time we've been able to get some quantitative idea of output voltage is when we had a reverse polarity setup and were just measuring open circuit potential.
We have 20 HV resistors from a cannibalized power supply rated at 50 M Ohm, I'm not sure of the power rating but they're fairly chunky, approx. 5 cm long and maybe 2 cm in diameter, which I'm guessing should do the trick. If I stick 4 of those in series for my R1, and have a max operating voltage of say 50kV, they'd each dissipate 3.125 W of power which I think (and will verify) is within their operating specs. Then if I had a DMM with 10 M Ohm impedance, I could pick a R2 of 200 k Ohm and have close to a 1000:1 ratio. Do you think I could substitute a 200 k Ohm potentiometer in place of R2 so I could calibrate the divider using the electrostatic voltmeter as a comparison?
DaveC
Post by DaveC » Fri Apr 11, 2008 6:58 pm
Josh --
Those components sound like just what you need.
You've got the idea about the voltage divider.. you can just either just ignore the small error caused by the DVM loading or... calculate it out and make a 1 v= xxx kV chart or list. A lot of the time that's all I do. But if you've got a good stock of 1% resistors in the precision resistance ranges... (finer intervals of resistance)... you can probably just sort through the values and get something that very close exact. DVM's internal resistances are also NOT exactly 10M or whatever.
I use a 6-1/2 digit DVM to read all these values, so you see the variations all the time.
I didn't think the Electrostatic Voltmeter was polarity sensitive. Those things work on the reduction of energy principle... and the force is proportional to E^2 , So they actually should be indifferent to polarity and.... to AC or DC. They are almost exactly like a old air-spaced parallel plate tuning capacitor, like those that used to be in every radio... except that the movable plates had geater spacing and were pivoted like a meter movement.
I'll dig mine out and double check.... (Ask your E&M prof..about energy conservation principles applied to this sort of device.... but be prepared for some "extra credit " homework to show its characteristics.)
The potentiometer is also good. Just be sure to use the outer ends of the resistance element for the connections to HV resistor and ground. The DVM goes on the slider and to ground. This way you don't have to worry about slider contacts getting intermittent and routing the HV in strange and wonderful directions.
MSimon
Post by MSimon » Sat Apr 12, 2008 11:03 pm
Current shunt:
Assume your meter has a 200 mV movement and you want to read out 200 mA Max.
A 1 ohm resistor in place of the Amp meter will do the trick. Then just read the voltage across it. A 1/4 W resistor should give you plenty of margin.
Other values could be used if direct reading is not critical.
You can also check for high frequencies by putting an O-Scope across the shunt.
If you want a higher voltage for measurement purposes (2V range) Make your resistor 10X larger.
In this application current shunt voltages up to 20V will not have a serious regulation effect on the power supplied to the fusor.
MSimon
Post by MSimon » Sat Apr 12, 2008 11:19 pm
Another way to handle read out is to use a 110 Mohm resistor for dropping most of the voltage. Put 1 M ohm in series with that. add 100 K plus 10K in series with that.
Read the voltage across the 100 K. That should put you within 2% with a 10 M meter shunting the 100 K. If you want to get within the error of your resistors add a series resistor of 10K to the string and do your read out across the 10K.
Do the math. It is very interesting.
That kind of voltage divider means you can use standard decade values rather than having to find say a 999 M ohm series resistor plus a 1 M ohm or some such unobtanium.
That is a pretty slick trick I worked out when trying to figure out how to make a divider from standard parts.
Post by John Futter » Mon Apr 14, 2008 9:54 am
Josh
all the afore mentioned advice is right, but you will need to take some extra precautions around the DMM readout device.
The input to your final readout needs transil diodes across the inputs to supply rails.
This is protect the readout devices is case of a sudden breakdown /arc /whatever that will fool your divider (dV/dT, dI/dT) and input a nasty transient into the readout device.
Transils across the input = rating = to the supply volts for the readout
GDT across the divider min voltage available =90 volts but it is very fast
After the GDT across the divier put aircored inductors to slow the voltage spike for the Transil to react across the readout device input terminals.
may your electronics live long
Or if you can get it a sensitive analog meter with apropriate scaling resistors (with back to back diodes across the movement to protect it)
MSimon
Post by MSimon » Mon Apr 14, 2008 12:31 pm
John,
Good advice. However the device you want is called a Tranzorb. A least in the USA. They break down in 1E-9 sec or less. If you want to look at RF across the current shunt get some low capacitance devices. You can get devices with shunt capacitance as low as .5pF. Do an RC time constant calculation .16/(shunt resistance * transorb capacitance) to get the 3dB frequency.
A tranzorb in the 5V to 10 V range should be OK - expect peak voltage of around 2X the rated voltage during a portion of the breakdown event. A voltmeter should be able to handle 50V on the .200 V range so your meter should be protected.
SteveZ
Post by SteveZ » Mon Apr 14, 2008 4:07 pm
One minor issue with this design is that with the voltage monitoring circuit on the fusor side of the ampmeter, you will also be reading the current flowing through the resistor divider and voltmeter. While the current will be fairly small, so is the current through the fusor. I'd move the voltage sense circuit across the bridge rectifier to reduce the error factor on tour current sensing. Just a thought.
AFW
Post by AFW » Mon Apr 14, 2008 9:50 pm
Josh- I think the transformer secondary will have about half the DC output superimposed on its AC, which might cause breakdown unless the insulation is very good.
Tony webb
