Spellman DXR3000/LC -- Help??
lucian
Real name: lucian
Re: Spellman DXR3000/LC -- Help??
Post by lucian » Thu May 03, 2018 7:37 pm
Hello, I know it has been a few years since someone posted on this topic. ... i am looking for the manual for this system .. does anybody still have the manual ? would you guys be interested in sharing it ?
Jackson Oswalt
Real name: Jackson Oswalt
Post by Jackson Oswalt » Fri May 04, 2018 12:23 am
Please change your username to your full name and introduce yourself in the "Please Introduce Yourself" section. Thanks!
Youngest person to build a Fusor at 12 yrs
Adam Binns
Real name: Adam Binns
Post by Adam Binns » Fri May 04, 2018 1:42 am
-Greg
you may want to use the capacitors to smooth out the rectified wave-form otherwise it will have the same properties as AC.
You could also get high voltage cable and wrap 20-50 turns around an iron core to act as an inductive ballast also, you might want to calculate the conversion rate from AC to DC as it can increase the voltage output drastically.
"it's not illegal just don't get caught"
