Snubbers
ChrisSmolinski
Snubbers
Post by ChrisSmolinski » Sun Jan 30, 2005 2:22 pm
I know there's a few HV gurus out there, perhaps someone has some
suggestions for replacing standard RC snubbers with something more
elegant.
I have a HV supply (my own design) that uses a pair of MOSFETs.
96V DC is applied to the center tap of a transformer, the MOSFETs are on
the two windings, to ground, switching at around 12 kHz. There's then some
boost windings, and the output goes to another transformer which drives a
standard diode/cap multiplier stack.
As of now, for MOSFET protection, I have diodes across the drain/soure to
protect against negative spikes.
I am also using RC snubbers: a 5.6K and 0.22uF in series, across the two
MOSFET sources, and 11.2K and 0.11uF in parallel with each other, that in
series with a diode, from the MOSFET source to the 96V DC supply
(transformer center tap). All values emperically derived.
The resistors are bukly power resistors, and dissipate a bit of heat. I'm
curious if anyone has tried just using some of the fast protection diodes that
are available today at various voltage ratings, and putting them from the
MOSFET source to ground, with a breakdown voltage somewhat less than
the MOSFET voltage rating?
Richard Hester
Re: Snubbers
Post by Richard Hester » Sun Jan 30, 2005 10:33 pm
The only thing you really need to do with snubbing is to suppress the transformer leakage spike to keep the mosfets from breaking down. Most mosfets these days have a repetitive avalanche rating, but it's not really good for them to break them down each cycle. What you want to do is hang a fast recovery diode on each drain with the anode pointed to the drain. Hook the two diode cathodes together. From this junction, hang a parallel resistor -capacitor combination from the diode cathodes to the transformer center tap.The capacitor should be large enough to limit the voltage excursion of the drains to a value comfortably less than the mosfet breakdown voltage. The resistor discharges the capacitor between hits. You want to adjust the RC values such that when the converter is running under load, the capacitor voltage stays above 2 X Vin, but doesn't get too close to the mosfet breakdown voltage. This is to prevent the snubber from diverting a significant potrtion of normal energy transferred through the transformer, which is what will happen if the voltage on the snubber capacitor drops below 2 X Vin. You do essentially the same thing by placing a series combination of diode and transient suppressor zener across each mosfet from drain to source. The diode would be to prevent reverse conduction of the zeners during the switch dead time. The breakdown voltage of the zener would be sized to be higher than 2 X Vin, but less than the mosfet breakdown voltge. The zeners would also have to be sized to dissipate the leakage energy without overheating.
DaveC
Re: Snubbers
Post by DaveC » Mon Jan 31, 2005 8:28 am
Chris - the snubbers can really make your MOSFETS work hard. The fast Shottky diodes are a good idea. Also, I have found it hard to tell what transients are real and what are artifacts of the scope hook-up.
Re: Snubbers
Post by Richard Hull » Mon Jan 31, 2005 3:32 pm
The Motorola HEXFRED diodes are pretty fast and are able to take a beating during reversals. They are very expensive though in the higher voltage and current ranges. Make sure they are located real close to the device they are to protect.
Richard Hester
Re: Snubbers
Post by Richard Hester » Mon Jan 31, 2005 6:10 pm
Snubbers/clippers are a necessary evil. If Chris uses them the way I suggested, they will have a minimal effect on the MOSFETs during steady state operation, as they will be biased as "clippers" rather than your classic load-line shaping snubber. The MOSFETs will take a small hit when initially charging the clipper cap, but they can take this in stride.Ditto for the transient suppressor zeners. Hexfreds might make decent antiparallel commutation diodes for the MOSFETs, but they won't be very useful for snubber duty. What I need from Chris is the breakdown voltage of the MOSFETs he is using, and I could give a rough ballpark guess as to the size network that will be needed. With 90-odd volts on the input supply, 200V MOSFETs would be cutting it too close for any sort of safety margin. This is because with a push-pull topology, the switches see a minimum of 2 X the supply voltage, not including leakage spikes. Even a 250 V device is cutting it close, as it doesn't give much room for the snubber to operate. At least in the case of IR, the next notch up where there are some decent devices to pick from is 400V. If you could find a substantial 300V device, that would also be ok.
ChrisSmolinski
Re: Snubbers
Post by ChrisSmolinski » Fri Feb 04, 2005 11:04 pm
It's the IRFP460, rated 500V.
AnGuy
Re: Snubbers
Post by AnGuy » Sun Feb 06, 2005 7:58 pm
I recommend two Hexfreds: one between Source and ground of your mosfet and another between source and drain (in reverse). Mosfets have a built in snubbing diode across the source and drain, but an external diode will help reduce the power dissipation on your mosfet. Some of the books I read mentioned using a CRD network across the source and drain:
|--- S ---+
| C1
| D1 R1
| ---D----+
D2
GND
The faster the switching response of the snubber diodes the better.
Richard Hester
Re: Snubbers
Post by Richard Hester » Sun Feb 06, 2005 9:54 pm
It's important to get your terms straight. The antiparallel diode to which you refer is for commutation of the transformer magnetizing current when both switches of the push pull converter are off - it has nothing to do with snubbing. One can possibly get away with using the intrinsic diode of the MOSFET for commutation if the current is low, but it puts extra stress on the MOSFET to force recovery of the intrinsic diode, as its recovery time is usually relatively slow. I've blown up MOSFETs that way in a half-bridge converter, but it was a fairly large current and old-technology devices. The key to getting the commutation diodes to work is that they should have a forward voltage lower than that of the MOSFET intrinsic diode and a short forward recovery time. Hexfreds could qualify if they are large enough. Steering the current into the commutation diodes is more difficult than it appears, because the intrinsic diode of a large MOSFET like the IRFP460 will have a relatively small forward voltage drop because of its large area. Sometimes designers place a Schottky diode in series with the switch and place the commutation diode across both the Schottky and switch to make sure that the reverse current only flows in the commutation diode.
Attached is a picture of both the commutation schemes I have described, as well as two schemes for drain snubbing/clipping. Returning the clipper capacitor to Vin rather than return allows the use of a lower voltage capacitor. Starting values for clipper capacitor - 4.7-10nF, make the time constant of the clipper capacitor and discharge resistor at least 2-3 X 1/f, where f is the switching frequency. These will be starting values. Start with a small load on the supply, adjust C as needed to keeep the leakage spike voltage < 0.8 Vmax at max load, where Vmax is the max drain voltage rating of the switch. Adjust the clipper resistor so that the voltage on the capacitor doesn't fall below 2 X Vin.
The last scheme shown is a simple zener diode clipper. The series diodes for the zener diodes may not be necessary. For zeners try something like 2 X P6KE150 or P6KE200 in series. You could also return the zeners to Vin, in which case one would use a lower breakdown voltage zener, and the series diodes would be necessary. Be careful of overheating in the zeners, as they will run away thermally if they get much over 100C.
MARK-HARRISS
Re: Snubbers
Post by MARK-HARRISS » Mon Feb 07, 2005 2:12 am
Thanks, I've printed that for future reference.
Mark H
Richard Hester
Re: Snubbers
Post by Richard Hester » Mon Feb 07, 2005 3:16 am
Here is the alternate arrangement for the zener clipper circuit, in case my description was not sufficiently clear.
