Power Supply Suggestions
I would like to hear from members who have a working Fusor as to what type of power supply they are using. I am looking to see what type I need to find to power a neutron fuor. Carl's advice is to use an X-ray tranny like in his setup. I would agree as it has a high voltage range and current. Would that be the best route for me to go? If so, would I just need a variac since its output is already rectified? And would I need a variac over 10 amps? Like to hear others thoughts on this.
Re: Power Supply Suggestions
I'm currently using a rack-mounted unit by Glassman High Voltage out of High Bridge, New Jersey. It has a variable output from 0-125KV DC at 0-7.5mA. It even has reversible polarity for glow discharge mode. It only weighs 30 pounds and takes up only 5.25 inches of panel space. After many botched attemps at assembling my own, I sprang for a professionally made unit. They cost a bit, but I have to say it's been worth it as far as my data is concerned. Nice specs, and very user friendly with front-panel controls.
Brian, you are scheduled to come to my bash here in October. You will see my setup then.
I use a simple 80kv X-ray transformer with full wave rectification under oil. No filter caps. I control the output voltage with a 6kw variac.
I will have about 30 variacs for sale at the electronic/scientific flea market we have at this event.
The power supply of any neutron producing fusor should have a capability of 2KW at least. Most fusors work at or just under 1KW.
- Real name: Jon Rosenstiel
Brian,
Carl is 100% correct.
I'm using a fairly old, uses tubes, (Kenotrons), for rectifiers, GE 100kVp x-ray supply. (100kV between the anode and cathode leads, 50kV either side to the case). My variac is a 15A, 240V model.
Once you have one of these babies you'll never need another power supply! I've screwed around with NSTs, (ok for a demo fusor, but that’s about it), flybacks, (lotsa’ voltage, but the current sucks), and I don't remember what else, and this old x-ray power supply beats them all, hands down! The HV control is as linear as can be, from zero to a little over 50kV. Plenty of current for any HV project I can imagine.
I bought mine from Chris Boden of the "Geek Group". (Tesla coil dudes). The shipping from Ohio to California was a killer, but I don't regret it one bit!
If you go the x-ray power supply route just be sure to treat it with respect because it can bite! HARD!
Jon Rosenstiel
Jon Rosenstiel
Did you purchase your Glassman new?
