I'm currently building my permanent power supply unit, fitting the transformers and variac into a case with metering and safety interlocks on the doors and I'm at the stage of deciding what filtering to use on the bridge rectified DC output. Do I need any serious form of filtering? I'd like to avoid a 50KV oil filled homemade capacitor If I possibly can from a safety point of view, not to mention vapourising grids with sudden flashovers. I'd like to know if straight inductive filtering is feasible to take some of the bumps out of the 100Hz (rectified 50Hz) output. Time to reach for the ARRL handbooks I think.
Regards
Mark Harriss
Do I need filtering?
Re: Do I need filtering?
I no longer use filtering on my system. I was actually creating false counts as the thing broke into a relaxation mode oscillation. Usually, this happened just as real fusion voltages were reached.
If you opt for filtering, figure on about 15ma draw in operation. Most of the time a .01ufd is enough.
