Custom Fusor Power Supply
Real name: Mark Rowley
Re: Custom Fusor Power Supply
Post by Mark Rowley »
Over the past three days I’ve literally thrown the kitchen sink at the supply and have had no reportable performance issues. Collectively, it’s now got about two hours of run time and has incurred two 30 minute non-stop operational runs.
Tonight I decided to “destroy” the supply by running it full tilt (saturation point of the rewound MOT which supplies the driver). Well, it wouldn’t fail, just kept going and the neutron numbers just kept climbing. The maximum raw CPM/N on the Ludlum 2221 was over 23,000. Based on this fusors ability to load, I’d suspect tomorrow’s run will be in the mid 30k range.
So far the value of the multiplier caps are remaining true to their specs. But tbh, I really don’t care if one blows out at this point. Each capacitor is about 50 cents, so if I have to replace one every now and then it’s no big deal. Additionally, it’s modular design makes for a 10 minute process to replace. The performance to capacitor replacement ratio is well worth it...providing its ultimately required.
Now the real difficult stuff begins, getting the gamma spec system up and running. We built a new computer a month ago and the sound card isn’t working well with the MCA software. The ultimate goal is to activate Molybdenum and detect Technetium via the MCA, so that’s now priority.
Here’s the latest run with the flyback supply. Please excuse the clutter, I know it’s a mess:
https://youtu.be/arbNemCBjho
Great work and a great supply. Nice video. You continued removal of the 3He tube from the moderator is great. All newbies need to take special notice of this wonderful proof of fusion with a thermal neutron detector as "running proof" that you are fusing. It looks like you have a super supply that is fully capable. Again, great work.
Real name: Dennis Brown
Post by Dennis P Brown »
A really impressive feat on the PS. Good pics. Also, could you supply a schematic of your power supply?
A pic of the fusor and overall system would be nice, too.
Thanks Dennis
The fusor hasn’t changed at all. It’s the same as listed in the original threads.
viewtopic.php?t=13503
viewtopic.php?t=13536
Regarding the schematic, I really dont have one as it’s assembly is extremely basic. On page one, you can see the basic outline of the components which almost by itself is a perfect schematic.
In a nutshell, it’s just 4 custom AC flybacks being run in parallel. The outputs are individually fed into separate single stage multipliers. The outputs of the multipliers are placed in series providing the 60kV.
As Richard correctly pointed out, the ceramic capacitors do tend to loose some value after lengthy run times. However, nothing to the point where performance was compromised, at least to a noticeable level.
Twice now, I’ve intentionally pushed this design to the point of destruction. The last failure occurred at ~89kV / 5mA. A arcover condition occurred in the #4 multiplier causing a surge that took out half the diodes. Zero damage to the flybacks, ZVS driver, or caps. The diodes were rated at 20kV (which is ok for the multiplier circuit) but the almost 90kV arcing over made the diodes easy pickins. Being that I designed this to be a 60kV supply, the failure is actually a success. A success that under harsh conditions the flybacks survived as well as the driver. Replacing the diodes only took about 30 minutes and it was good as new. I’m fairly pleased as it’s proven to be a very stable design for 60kV.
I’m currently in the process of making a couple design changes that may or may not make a difference. First, each multiplier will be changed from half wave to full wave. And secondly, I’m replacing the ceramic caps with 2nF 30kV poly/foil types. As with the ceramics, I’ll be periodically checking the values for any signs of degradation.
Once reassembled I’ll update.
Bob Reite
Real name: Bob Reite
Post by Bob Reite »
You might be able to get away with smaller capacitors if you switch to full wave, as the ripple frequency will now be doubled.
Finally got around to building the multiplier module with the new axial poly caps. As before it’s a very basic arrangement except that this version is full wave and a bit bigger due to the larger caps.
Had just enough time to conduct a brief 10 minute test run with the fusor. Operationally I didn’t notice much difference but it does seem to have a slightly higher voltage ceiling. Over the next few weeks I’ll focus more on long term sustained runs as opposed to pushing it to the point of failure.
Very impressive build and I really like the clear box for the VM system and x-formers.
One suggestion for the future (well, two.) Use balled solder joints for joining wires and do away with sharp corner metal nuts where ever possible (I use plastic hardware.) Even under oil these issues can lead to problems for long term high voltage operation.
Thanks Dennis
Those clear containers are actually medical radioisotope lock boxes. Very thick plastic and 100% leakproof (as mandated by hospital regs). By sheer luck the size was perfect and the need for modifications was minimal.
Another mod on this go-around was the addition of fused quartz insulator sleeves between the primary windings and the cores. I also elected to rewind flyback #4 while saturating the wire in Alumalite epoxy resin. Very little air (if any) is within the windings. Expectedly, this mod alone almost doubled the output of the flyback. As stated earlier I wanted to avoid that type of arrangement as it makes coil repair almost impossible. I used a different method of winding this time which may allow for repair... hopefully such a repair won’t be necessary. The flybacks have actually held up nicely unless I push them way beyond what I designed them for.
If I end up doing major surgery again I’ll try the blob method on the solder joints. There are only two areas where this could be mostly beneficial.
Conducted a sustained 30 minute run this afternoon at roughly 1.5E+6 n/s TIER. No signs of problems so this just may be the final iteration for awhile.
This is a video of it powering the fusor during the aforementioned run. The noise in the background is the Ludlum 2221 counting the moderated neutrons.
https://youtu.be/gGG1GeDi3nw
I have some larger ferrite cores I may try this upcoming summer but for now I’m fairly pleased with its performance.
It’s been about 6 weeks and roughly 20 runs since the last update. No problems with performance and the poly caps are holding up perfect with no change in value.
In the meantime I’ve been experimenting with some different flyback cores as well as epoxy encasement. Initially, epoxy was off the table as it eliminated the possibility of any repair to the windings. However, since the supply has been tested under adverse conditions which would normally obliterate a commercial precipitator unit, it’s concluded the larger gauge windings and stronger diodes removed most of that concern. For comparison, I wound an identical flyback but this time encased the windings in Alumalite brand clear epoxy. By doing so it almost tripled the voltage and current capacity over a non-resin flyback which only used mineral oil as an insulator.
This opens the possibility of completely removing the multiplier circuits and running four rectified ~20kV custom flybacks with the outputs directly in series. In theory, this should greatly increase the current capabilities of the supply.
Impressive work; you are really setting the bar for a home made power supply for a fusor that most could build. Keep experimenting and posting - you've created a great thread.
Ordered a set of beefier cores and made new secondaries with 2000 turns of #30. Each secondary was wound while submerged in epoxy resin. The single stage multiplier circuits will employ 40kV rated 100mA diodes. Preliminary testing will begin in a few days.
The unmultiplied output in series (under load) could be high enough to operate a fusor with little to no issue. Testing on that aspect will happen later but first will be a reduction in multiplier capacitor value to 510pF. Those items are still on order so the original multiplier module will be employed until then.
Those are beefy cores! Wound under epoxy resin? Slow setup time I image? Arc proof if under oil for sure.\
Great effort!
Where did you get the cores?
Hi Dennis,
Picked them up on Amazon a few months back. The seller recently more than doubled the price for a pair as they’re now almost $26 a set. Id look elsewhere for a better deal.
Quick update on this supply. The last iteration with the beefier cores did not operate as expected. The composition of the cores did not provide proper inductance so the system was reverted back to the original smaller cores.
The PSU was a true performer for the fusor it was designed to power.
Matt_Gibson
Real name: Matt Gibson
Post by Matt_Gibson »
What type cores did you try out?
-Matt
Being almost a year ago I no longer have the exact specs and they are no longer offered from the seller. The above pic indicates their size. Another issue was the spacing between the primary and secondary. Too close and I'd suspect it'd ultimately break down.
Regardless of all that, the smaller cores were/are the bees knees.
Yosef Herrera
Real name: Yosef Herrera
Post by Yosef Herrera »
Good Morning,
Hope you are doing well. Hopefully, I am not asking something already on the fusor Q&A or elsewhere but could you provide the calculations conducted to design this power supply?
sincerely,
Yosef Herrera
