Soldering Ceramics
Peter Schmelcher
Real name: Peter Schmelcher
Soldering Ceramics
Post by Peter Schmelcher »
Applied Science (YouTube channel) built an ultrasonic ceramic/glass soldering system
Includes links to references. The guy goes all in and has good content.
Aside: I usually watch YouTube using fast playback between x1.5 to x2.0, unfortunately for some clips the maximum playback speed is not fast enough. I also use the player keyboard hot keys to change the speed and jump back for quickly spoken comments in an otherwise slow video.
https://www.youtube.com/watch?v=WuYdsStS1MQ
Re: Soldering Ceramics
Pure Indium or alloys of tin-indium, where the In is the greater part of the alloy to the limit of 50:50, will wet glass and ceramics for soldering without ultrasonics, just normal heat. I have mentioned this here before. However, be it ultrasonic or normal heat with indium-tin alloys, the melting point is critical in a fusor where the melting points can present an issue. The weakness of all these joints from a mechanical standpoint is also key as noted in the video. For special non-thermal environments where electrical connection is paramount and low bond strength is acceptable, all these methods are fine.
Justin Fozzard
Real name: Justin Fozzard
Post by Justin Fozzard »
Richard's suggestion of using Indium to wet the ceramic surface is a very good one, though I haven't tried it yet.
Strong in his excellent "Procedures in Experimental Physics" mentions a few methods, one involving platinum that may be a bit expensive, another being to use a silvering solution to deposit a thin layer of that metal. I've used the Rochelle salt method that he mentions to coat glass mirrors and flasks with a thin conductive layer of silver.
I have a pdf of the Strong book but unfortunately, at over 10MB, it is too large to post here; I would be happy to email a copy of it if you PM me.
Kohl has a chapter in Beck's "Handbook of Vacuum Physics", below, that discusses ceramic to metal seals, and although he advises getting a specialist company to produce them for you he does mention some techniques.
If you have a high-temperature vacuum furnace or can rig up an inert gas one then it may be possible to fuse a powdered metal to the glass or ceramic as Kohl suggests.
Post by ian_krase »
I've been interested in DIY ceramic to metal seals. It seems possible that with the right hacks we could make these in our own vacuum systems. Sadly, I usually haven't seen much that's really interesting/successful.
Peter Schmelcher
For scale the neon sign glass tube is 6mm in diameter. It was heated while passing through a ring of hydrogen oxygen torch flames and today we would think of this as a 3D printing extruder.
A reducing torch flame (with excess hydrogen) would leach oxygen from the glass tube surface resulting in a metallic surface on the glass. Oxygen was always adjusted until the metallic blemish vanished so I can’t comment on the metallic properties. What I remember is that it could not be cleaned off and that the blemish varied from transparent black to a shiny metallic mirror. I quickly put an ohm meter across a mirror blemish and discovered that it was not conductive, however, this was not a proper test.
Today decades later, I wonder if the blemish would make a good vacuum sealing bonding surface.
I like the idea of indium seals but the low melting temp is a bit of a drawback along with all the preparatory cleaning. I keep thinking of spinning glass and pressing an indium rod against the glass and using friction to create a thin indium film coating. Finally electroplate some copper on top of the indium and solder parts together.
Indium and copper are miscible and form a very hard alloy. The alloy ruins the grip of the indium to other media. In general any alloy to wet glass with indium must include 50% or more indium. A good solderable alloy is 50:50 In:Sn. I have mentioned it before. I make up a lot of low melting point alloys for both my own use and for special purposes for others.
