High Voltage System Approval
Steven_Udotong
Real name: Steven Udotong
Post by Steven_Udotong » Sat Jul 01, 2017 4:16 pm
Hi Fusor Friends,
I've reached the stage my project in which I'm essentially done setting up the high voltage system. I would like to have my final setup approved by someone with experience before I switch it on.
Does anyone from South Jersey have some time to come to my house to view it next week? Or is it possible for me to PM pictures of the circuitry setup to anyone?
Thanks for all the support everyone!
Best,
Werner Engel
Real name: Werner Engel
Re: High Voltage System Approval
Post by Werner Engel » Sat Jul 01, 2017 4:24 pm
Hi Steven!
Why not post some pictures?
I will be happy to tell you what I know from my personal experience (if our PS are similar) ...
BR,
Werner
Steven_Udotong
Post by Steven_Udotong » Mon Jul 10, 2017 3:38 am
Hi Werner,
Thanks for the suggestion. Please visit this link below to see the pictures:
https://drive.google.com/drive/folders/ ... sp=sharing
Anyone else reading please give me some feedback on the setup.
Best,
Post by John Futter » Mon Jul 10, 2017 4:08 am
It is far better to upload the pictures to this site because
Google drive might disappear and then we are left with a topic with no pictures
This goes for Photobucket or whatever picture sharing site
It is easy to upload files especially if you resize re-sample to 1024 x 768 pixels
free software such as irfanview works great for photo manipulation
Werner Engel
Post by Werner Engel » Mon Jul 10, 2017 4:11 pm
It seems that someone else tried the same power supply in 2015: http://fusor.net/board/viewtopic.php?f=33&t=10040
The model looks a little bit to small for such a large power. So I think it might be constructed for pulse operation only??
Connecting a mass cable should be done in a professional way – reducing possible contact resistance and failures. The copper band you use looks fine – but the pipe it is connected to looks strange to me!
I would be very careful doing anything with this PS! Try to measure the inside resistance of all the connectors and have a look where there is high resistance and low resistance. This might help you identifying the right connectors. And you should try to get the manual!!
When operating the PS (only using the VARIAC and start at the lowest voltage) – keep distance to every conducting thing which comes close – at least 2 feet!
And have a HighVoltage probe ready to measure any voltages coming out of the PS.
Jim Stead
Real name: Jim Stead
Post by Jim Stead » Mon Jul 10, 2017 5:54 pm
Steven, A water pipe is not a good ground for a high voltage power supply. You can find a better ground in a nearby electrical outlet or wire. Tape is not sufficient for the connection either. Your ground cable needs to be mechanically attached to the ground, by screw pressure or something similar.
