Page 1 of 6
Christmas Comes Early!
Posted: Thu Jun 08, 2017 6:40 pm
by Garrett Young
(Note: I have no affiliation with the seller and can't guarantee the functionality of the listed item but I purchased one and will update the thread with my findings)
Spellman PTV50N200 (related thread: viewtopic.php?f=11&t=4852)
-50kV 4mA 200W (can be boosted to 7 mA/350W using the schematics in the linked thread)
http://www.ebay.com/itm/Spellman-50kv-H ... 2706614602
$125! (now $150)
Re: Christmas Comes Early!
Posted: Thu Jun 08, 2017 7:59 pm
by ian_krase
Oh wow.
Is that enough current though?
(Who cares, I'm not doing fusion for the *fusion*)
Posted: Thu Jun 08, 2017 8:06 pm
by Garrett Young
In my device, 50kV and 7mA would produce very easily detectable fusion.
Posted: Thu Jun 08, 2017 10:13 pm
by Garrett Young
Here are the changes that I identified to convert to the 350W version:
C15 0.047/50V
C39 0.022/50V
R50 4.7k 5%
JB5 IN (Used for Fan 24VDC)
R26 20k, 22T (?, table slightly unclear)
Posted: Thu Jun 08, 2017 10:24 pm
by Dennis P Brown
But your chamber operates at 33 milli-torr which is rather high compared to standard fusors (5 milli-torr); having a small 4-way "T" as a chamber is an apparent advantage and might be the best approach. So using 50 kV and 7 ma on a normal sized chamber might not work. I like your approach better but if someone wants to use a 350 watt PS might it might be best for them to follow your complete design.
Posted: Fri Jun 09, 2017 3:21 am
by ian_krase
Interesting.
I wonder if I can make an accelerator.
Posted: Fri Jun 09, 2017 6:35 am
by Sarvesh Sadana
Would it not be possible to purchase two power supplies and run them in parallel, giving you 50 kv at 14 ma?
Posted: Fri Jun 09, 2017 9:46 am
by John Futter
Sarvesh
This usually ends up with two lots of smoking ppwer supply remains
Posted: Fri Jun 09, 2017 4:40 pm
John is right, paralleling power sources to get more current tends to work better with batteries and even they need load leveling sharing resistors that waste power.
Posted: Fri Jun 09, 2017 7:13 pm
by John Futter
Actually i'm not quite right with the paralleling of supplies
some supplies have the capability to slave to a master supply so that there is only one control loop operating.
If you have access to the internal control loops and know what you are doing it is possible but I would say this is out of reach to most people here
