Spellman DXM70N600X3547 power supplies on ebay -70kV 8.56MA
Re: Spellman DXM70N600X3547 power supplies on ebay -70kV 8.5
Post by Rich Feldman » Sun Nov 27, 2016 8:56 am
I found C149 and CR34 both shorted. With those parts out, the DXM70 board DC rails are no longer shorted. Haven't yet installed replacements. For use exclusively on nominal 120 VAC mains, does anyone think the boards need or benefit from 450 volt rated capacitors?
The offending capacitor from my board doesn't appear to have bulged or leaked. Smoking gun was toasted FR-4 around the diode attachment holes. Sometimes that happens on working designs that have poor cooling or insufficient component derating.
That's a little snip from a full-board pdf file off a flatbed scanner, here in case anyone wants to carry on with reverse engineering.
dxm70_bot.pdf
(112.54 KiB) Downloaded 164 times
I experimented with Visio as a tool for reverse engineering. Took the flatbed scan and overlaid circles and rectangles, keyed by color, on various layers. Looks promising, and I already learned some practical details of half-bridge drivers etc.
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman » Sun Nov 27, 2016 10:21 am
The supply uses a PFC/boost converter system which increases the voltage to a few hundred volts, so the 450V cap is required.
Andrew Seltzman
www.rtftechnologies.org
Andrew Seltzman
Post by Andrew Seltzman » Sun Nov 27, 2016 7:50 pm
Here are 2 good references:
Spellman power supply reference
http://www.spellmanhv.com/-/media/Files ... manual.pdf
How to terminate cables for low corona/leakage
http://www.spellmanhv.com/Technical-Res ... age-Cables
Andrew Seltzman
Post by Rich Feldman » Mon Nov 28, 2016 10:53 pm
Those are great references, Andrew. Thanks for the pointers.
Speaking of group buys, how about some repair kits with the nickel-and-dime components that many of us found dead? If you have to order an individual item by mail, you can buy ten for about the same total money (after shipping charge).
As Peter said a while back, "The supply is conservatively laid out and the RTV is a good indication of vibration testing for harsh industrial environments. Honestly it would be a pleasure to work on if I had a schematic. So it’s just finding the hours to do a methodical investigation/repair with a budget of $100 for parts."
I don't think Cliff would mind if we continue to share notes about the bill of materials, and sourcing of replacement parts. Here's a piece of a schematic learned by inspection, as others here have done. So far un-reviewed.
Who wants to draw the power path from AC input through PFC circuit (Q10 and Q6), so we can see if it matches my scribbles? Can't see the label on my RV2 without removing the part, which measures about 24 ohms at room temperature. Can't see the label (or even the ref des) of rectangular pink capacitor next to the main bridge rectifier.
Almost forgot to mention, I made a DC resistance model of the whole interface coming up from the DXM70N's basement level. If the fancy inverter and control board were totally dead, or missing, why not use the potted "basement unit" to make a dumb HV supply, substantially derated of course?
Liam David
Real name: Liam David
Post by Liam David » Tue Nov 29, 2016 12:20 pm
I replaced the blown IRFBG30 mosfet on my power supply board, but it still does not function. I checked all of the capacitors, and C149 has a slight bulge but has no continuity. Otherwise none of the components on the board appear damaged. Removing the fan revealed that there is only about 2V on the bus, which I assume should be 24V. Any ideas what could be causing this problem? Some kind of bad voltage regulator? All six red warning lights on the front panel light up and blink repeatedly, so some power is going somewhere.
The other supply functions properly and I was able to turn the voltage up to 28kV. Still working on making a CA11 connector.
Cliff S
Post by Cliff S » Tue Nov 29, 2016 7:25 pm
Hey guys,
A few have emailed me on this one...
...I feel your pain on this...attached are a few sheets of the power section schematic. Below is copied from what I have been telling a few of you that have emailed me directly:
Re: C149: There is a history on this parts failure mode: It had to do with some applications, when keeping the DXM in standby, at elevated temps. I don't recall the details off the top of my head...but it had something to do with the PFC hiccupping at light loads, causing high ripple on the cap. Under elevated temps, and after years of operation, it would fail. I think you can replace it with a similar rated part, and in your application it will probably be fine.
I do see that many fusor guys have these DXM's off of eBay....a flurry of posts in the past week. This specific model X# has a particularly sorted past... to date we have shipped over 1,000 of these units to one customer for their food inspection system. We have wrestled with reliability issues early in the program due to our customer using these in a inadequately cooled cabinet. Ambient temperatures far exceeded the ratings of the supply. My guess is the customer has replaced many of the units in the field, and you guys are seeing these used, replaced units. Failures tending to be around the power semi's and in the HV section. (Some ceramic HV caps do not like high temps).
Your “X3547” l unit has some differences from the standard interface:
High Voltage Interlock: Pin 11 on J2 is the H.V. interlock in both local and remote mode. The hardware based dry contact closure must be closed in order to enable the high voltage via J2-15 in local mode or USB, Ethernet or RS232 mode. This can be done by connecting pins 11 and 12 on J2. The interlock must be closed prior to the unit being enabled. If the interlock is open and closed while the unit is enabled, the enable will need to be re-asserted to generate high voltage.
High Voltage Enable: Pin 15 of J2 is the H.V. enable for the local mode only. The hardware based dry contact closure must be closed to enable the high voltage. This can be done by connecting pins 12 and 15 of J2. This I/O is disregarded in remote mode.
Good Luck. Be safe.
7-8.pdf
(216.21 KiB) Downloaded 223 times
Andrew Seltzman
Post by Andrew Seltzman » Tue Nov 29, 2016 8:21 pm
Cliff, thanks again for the continued help you provide to the fusor.net community, I'm sure those pages will help a number of people debug their supplies. By the way, what is the -15v LVPS variable and what should it's normal value be(is this just the -15v DC bus voltage)? The manual also specifies that there are some test commands that you can send the supply, could you provide us with the syntax for these?
6.7 SPELLMAN TEST COMMANDS
 Program Hardware Version (Hardware setup)
 Program Model number(Hardware setup)
 Set USB Mode (Program USB)
 Set USB Page Address (Program USB)
 Send USB Page Data (Program USB)
 Toggle Passthrough Mode (Diagnostics)
 Store A/D Calibration Value (Hardware setup)
 Request Miscellaneous Analog Readbacks
Contact Spellman High Voltage for details and the syntax of these
commands.
Liam,
The IRFBG30 mosfet is part of a flyback converter that generates the 24V(first page of the schematic Cliff posted) that then is regulated down to all the lower voltages the supply requires. If you apply 24V to the fan connector this should power up all the digital circuitry/Ethernet interface for testing. If there is 2V on the fan connector when the supply plugged in I would suspect a problem in this flyback converter.
The converter draws power off of C149, what voltage do you have across this capacitor when the supply is plugged in?
Is the transformer primary ok(pins 3-4 on T2)?
Diode CR34 feeds voltage to C149, is the diode ok?
Andrew Seltzman
Liam David
Post by Liam David » Wed Nov 30, 2016 2:51 am
I applied 24V to the fan connector and the digital circuitry came on with a green system power light. This narrows the problem down to the converter. C149 has about 120V across it, diode CR34 is good, and the transformer T2 appears intact. Both secondary coils do have continuity between them, but I would assume this is because of other components. My suspicion would be that the UC3845 chip or the CL70 NTC thermistor is bad.
Andrew Seltzman
Post by Andrew Seltzman » Wed Nov 30, 2016 3:10 am
Check R206, if it is open the mosfet won't be sinking any current to ground.
Also check for an open in the traces between C149 positive and pin 4 of T2, the trace between pin3 of T2 and the mosfet, and the trace from the mosfet to R206.
Check voltage on pin7 of UC3845, it should be bootstrapped by the R192,R200,R197 resistor chain even if the boost converter is not working.
Does a relay click when you plug it in?
Andrew Seltzman
Liam David
Post by Liam David » Wed Nov 30, 2016 3:20 am
The relay does click when I plug it in. I will update this post tomorrow when I check the other components you listed.
