Spellman DXM70N600X3547 power supplies on ebay -70kV 8.56MA
Jim Kovalchick
Re: Spellman DXM70N600X3547 power supplies on ebay -70kV 8.5
Post by Jim Kovalchick »
I have been trying 192.168.1.4 since I first plugged the unit in. There was no response, that's why I was checking into whether my router was assigning an IP address dynamically. I see now that the manual implies that the unit must use a static IP. So, I think the failure mode possibilities are:
1. The static IP is not currently valid for my router and/or LAN. It's an Xfinity cable modem/router.
2. A previous user changed the IP. I believe this is possible since it would be required if more than one power supply was connected to the same LAN. The ominous part is that the manual suggests writing down changed IP's because there is no procedure for restoring the default.
3. There is an unspecified malfunction of the communications hardware in the unit.
4. Operator error.
5. Combination of more than one of items 1 through 4.
I believe item #1 is important to run to the ground. Based on the my limited understanding of the Xfinity documentation on the internet, it appears that you can use a static IP device directly connected to their modem but there is work I need to do in their 10.0.0.1 gateway to make the unit accessible to me on the LAN. Because they won't give me the username and password for the modem since it is paid for by my corporate account, the gateway is off limits. My options are to buy and install a router for a new LAN separate from the modem or to wait until my next trip back home where I already have a setup like that. The latter option is better for my wallet and therefore the best.
I'm not sure what to do in the case of failure mode leg #2.
For leg #3, I'm hopeful that the light status I'm seeing is a positive sign. The solid amber light indicates the connection is good and occasional green flashes show information is passing. I wish that I was also seeing green flashes on the router, but that could be an item #1 issue. When I scan the network with an app on my wireless connected phone, the unit immediately flashes for a few moments which I take as another good sign.
Leg #4 is always a possibility, but I can address that by spending more time with the manual.
Finally, I purchased a CAT5 crossover cable yesterday. I plan on attempting a direct connection to my laptop soon.
Kuba Anglin
Real name: Kuba Anglin
Post by Kuba Anglin »
I have also not been able to verify that my router identifies the power supply via direct ethernet connection. The IP address does not work. I logged into my Xfinity account at 10.0.0.1 and looked at all connected devices. The power supply was not listed anywhere. My supply does not indicate any signs of failure except this.
I also tried connecting to my computer through USB. This resulted in my computer stating that the USB device was malfunctioning. The manual of these machines was copyrighted in 2000, which makes me wonder how old these power supplies really are. Their software seems to operate on Visual Basic, the same language my grandfather used when learning computer science several decades ago. Something I want to try is installing a virtual machine on my computer that can run Windows XP, as the manual lists Windows XP as a compatible operating system. It is important to note that this virtual machine only works on Windows 7.
-Kuba
Andrew Seltzman
Real name: Andrew Seltzman
Post by Andrew Seltzman »
When I am connecting to the power supply my computer and the supply are both plugged into an ethernet switch that is separate from my router, the switch is also plugged into the router for internet/DHCP. Both supplies that I received were on 192.168.1.4, I might suspect the router if you are having problems connecting to the supply.
I would try the serial port, it's probably more straight forward then trying to get the USB to work.
default serial settings are 115.K 8N1
Serial commands start on page 94 of the manual PDF
You don't need to use visual basic, they are just using it as an example for code to communicate with the supply, matlab or any other software should also work
Andrew Seltzman
www.rtftechnologies.org
Dan Knapp
Real name: Dan Knapp
Post by Dan Knapp »
For those having problems with the digital interfaces, it might be easier to try analog control via J2. I'm still waiting for my unit to arrive. In the meantime, I sketched a circuit diagram for an analog controller (attached). I use a similar analog control box for another Spellman supply I have. This is a tentative circuit. I'll first try it without the LED indicators since I'm not sure how much extra current is available via pin 12 from the 15 volt supply when the enable input is jumpered. The manual implies that there is 15 ma available on pin 12, but it doesn't say how much the voltage enable connect (pin 11) draws. I'm guessing very little, but need to check it. I plan to pull the 10VDC reference voltage from one of the front panel pots (local filament limit control) by turning it full CW and using the pot wiper connection (pin 5) as the 10 volt supply. I don't know how much excess capacity the internal 10VDC supply has; I may have to disconnect the ground end of the front panel pot. for a really bare bones analog control to test the supply, one could just use a pot across a 9 volt battery to supply the control voltage to pin 3.
I haven't actually built the box yet in case my supply arrives DOA, in which case I plan to return it.
DXM Control Box.pdf
(72.23 KiB) Downloaded 459 times
I do not have one of these items and at the risk of butting in and looking the "outsider fool", I think Dan's post and PDF diagram, above, is the way to go. This is far too easy to hook up and check out via hard wired connection to determine whether any of you have a "pig in a poke" or the greatest thing since sliced bread. This hookup is very spellmanesque and has saved me hours in the few spellman supplies I have encountered. They do often offer a simple hardwired control! (very wise).
All of this computer hookup and control effort over the 6 pages of posts here has left me much bemused. Any HV supply that has a 132 pin micro-controller can become a real nightmare and effectively unrepairable at any level save for the spellman repair shop.
Hardwire the thing ala Dan's diagram!!...This should tell the tale. Even then, if the micro-controller is involved and needs a critcal signal that isn't there or is FUBAR, you may still be out of luck.
As a last resort, a very crafty work around might be possible if a genius in electronics can find a "bypass" to the micro-contoller. (all the best on that quest)
We are slowly creating a morass of new electronics that involves incredibly complex and multi-tenticled micro-controlled devices that are readily deemed absolutely unrepairable at any level! This is fine if the item is made super inexpensive by micro-controlled electronics......Just toss the worthless pig in the trash and buy a new one that may be cheaper, still. (toasters, coffee makers, cell phones, Flat panel TV's, etc.) However, a new $4,000 item that had been a classic 100 pound, click on a power switch and turn the dial power supply in 1958 and is now an 8 pound USB controlled, ethernet connectable, supply with 15 new safety inputs and interlocking custom signals to a micro-controller can easily become an albatross to the amateur.
To the professional user who spent the $4,000 for the new bells and whistles supply, a $1,248.15 repair will work fine and if hyper critical to his process, a "hot swap $4,000" spare pulled from his store room will be on hand while the original is off for the kilobuck repair. The amateur scientist is not so well handled here with his $200 bargain.
I would like to hear from the first guy in this "recent" mass purchase group who actually gets measured voltage pouring out of one of these gems. I hope every single one will work fine.
I am not talking through my hat here.....I am a retired electronics engineer and currently designing, making and selling micro-controlled electronics.
Dan Knapp
Post by Dan Knapp »
I received my DXM supply today, but I fear I may also have a dead one. The fuses were good, the fan starts when plugged in, and the "power on" LED comes on. I can see it at 192.168.1.4 via the ethernet port and get the Spellman welcome page and software agreement acceptance, but the Java app will not run because "security settings blocked it from running." I need to figure out how to make a security exception to get the ethernet app to run.
I tried to control it via a DC control voltage into pin 3 of J2 (voltage program input) and pin 11 connected to pin 12 to enable, but I see no voltage on the HV output connector. I also don't get the "x-ray on" LED lighting up when I connect 11 and 12 to enable. I need to study the manual some more to make sure it's not operator error, but I fear this unit is DOA.
The seller has a 14 day DOA return policy, but the buyer pays for shipping both ways when executing this mode of return. These units were advertised as "fully functional" and therefore should come under the eBay guarantee where the buyer gets a full refund and the seller pays the return shipping. If I conclude that the unit is indeed dead, I will return it under the eBay warranty process. Since it appears several other peoples' units were received DOA, I'll let you know how things go with this.
Jim Kovalchick
I was able to make a direct connection to a laptop running Windows 10 using a crossover cable.
The applet starts to run but stops without loading the data. I am guessing this is a compatibility issue to newer versions of java and/or the browser.
I am happy to get this far and will probably wait to run this on an old pc at my home lab.
Andrew Seltzman
This custom version of the supply requires an additional HV enable signal on the 15 pin connector when running in local control mode(not over ethernet).
The high voltage interlock must first be enabled by connecting pins 11 and 12. In addition in local control mode(not required for Ethernet/RS232/USB) an HV enable signal must be given by connecting pins 15 and 12. If the interlock is opened in local mode then the enable signal must be re-asserted again(cycled open then closed) after the interlock is closed for operation.
The "x-ray on" light will not come on until some threshold voltage(not sure about actual number, but it's a few kV) is reached on the output.
The applet problem is due to the new versions of java, it won't work on any newer systems, you have to use the ethernet commands in the manual.
Andrew Seltzman
Peter Schmelcher
Real name: Peter Schmelcher
Post by Peter Schmelcher »
Andrew the 24V powering is an interesting diagnostic approach. I think I will fix the board first and then commission it using the 24V idea. Having a working supply my approach will be to compare the unpowered differences diode drops and resistances between various nodes in the effected area between the 2 supplies. Then powering up the good one I will scope similar nodes to better understand how the circuit failed.
The board was overheated at this via which is an easy fix with some copper wire and solder. Components visibly involved are K3, RV2, C149 and R218. Probably overstressed and also worth replacing include CR35 and CR34. Then the issue of finding the root cause of the failure immerges. About $70 of FETs are mounted on the internal heat sinks and if any were over stressed they should probably be replaced as a set. The supply is conservatively laid out and the RTV is a good indication of vibration testing for harsh industrial environments. Honestly it would be a pleasure to work on if I had a schematic. So it’s just finding the hours to do a methodical investigation/repair with a budget of $100 for parts.
My good unit works fine and the software hobbs meter reads 194 hours of on time (I don’t have matlab). I used a Fluke 8060A meter and Fluke 80k40 40kV probe. The probe easily fits into the CA11 socket and I tested the supply via Ethernet to 30kV in 100V steps while monitoring the actual output voltage with the probe. Wattage testing is for another day.
By chance did you inquire about a schematic?
-Peter
Andrew Seltzman
I have a schematic of the control board but have been asked not to publish or re-distribute it since it is a proprietary design of one of their flagship supplies. You could try contacting Cliff Scapellati at Spellman and see if he will send you a copy. In the meantime, if you send me a list of problems your supply is having I'll have a look and advise you what components to check.
I recommend the 24V test first since if the digital control system is fried, the power supply is likely damaged beyond repair, even with the schematic, and I might recommend returning it without trying the replace the power electronics. The 24v test should be very easy to accomplish and can be done without repairing the damage to the power input components.
R218 is a 0.05ohm, 1%, 5W resistor
K3 is a t90s1d42-24 POTTER&BRUMFIELD relay
RV2 is a CL70 NTC Thermistor
C149 is a 33uf(marked as 68uf in the default schematic but 33uf in my supply) 450V capacitor (Digi-Key Part Number 565-1423-ND )
CR35 is a GBPC3508W rectifier
CR34 is a MUR460 diode
RV2 is an inrush protection varistor, once the filter caps charge through the varistor, the relay K3, which is in parallel with RV2 should close, bypassing RV2. If this failed to happen, the full current of the supply was probably being drawn through the varistor causing it to burn. Try replacing the varistor and relay, in absence of any evidence of a short circuit or other damage this may get you up and running.
Could you send a picture of your full board showing damage to the other components?
Andrew Seltzman
Post by Rich Feldman »
Picked up fuses today, but didn't yet repeat the AC "power up" exercise.
Instead I tried the 24-VDC jump start trick, with gratifying success.
After separating fan from circuit board at the connector, ran fan and then circuit board from an adjustable bench power supply.
In the picture, PS common is connected to TP6 with an alligator clip. PS + is connected to fan header using a single receptacle contact.
When voltage was ramped up to 24V over a few seconds, a relay clicked and a bunch of LEDs came on, including several red front-panel FAULT indicators. I bet the ramp was too slow to trigger "power-on reset" behavior. Switching the PS off and back on did the trick: no LEDs on except front panel power indicator and one internal green LED. Current = 0.28 amps. All test points labeled with voltages (+3.3, +5, +10, +15, etc.) had the expected voltage values. One pin in bottom row of J2 (the DA-15 connector) had +15 V on it. So far so good.
Guess the next step is to reconnect the 120-VAC input module, with a fresh fuse, and plug it in to see what happens. Got no experience with troubleshooting any SMPS, much less a ZVS with PFC input. Could a current-limited startup using a series ballast (bypassable with a manual switch) do any harm?
Andrew Seltzman
I'd say try it without the ballast but with a lower amperage fuse, the power supply shouldn't draw much current to just power up the control circuits and would only need the rated fuse for running at full power. Perhaps start with a 2A or 4A quick blow.
If you plug in the Ethernet when 24V is applied, can you communicate with the supply?
Andrew Seltzman
Stefan Gustafsson
Real name: Stefan Gustafsson
Post by Stefan Gustafsson »
I was able to acquire one the supplies as well. To bad after shipping it over to Europe it was DOA. One of the fuses are bad and the VR2 thermistor is cooked.
It also looks like one the capacitors is broken. If I measure the resistance over the capacitors it's zero ohms.
I have been able to start the digital part up using a 24v bench supply and Ethernet commands works so I'm hopeful. Thank you very much for that information.
I rewrote the mathlab code into a C program if anyone is interested.
I will start removing broken components until I can find the short-circuit and try to rebuild the power parts.
The unit is marked with 115V but the product manual says 180-265V input.
Andrew, can you find any other changes to the selected components that would make it impossible for me to run my unit on 230V as here in Sweden?
Jim Kovalchick
I am not a coder and don't use MATLAB. Given that the GUI applet doesn't seem to be happy with modern versions of JAVA, I need to find a way to send TCP commands that works for a dummy like me. Surfing this morning I found a free utility called Packet Sender that it looks like it would work to send and receive data from a network based device like the DXM. I hope to try it soon, and I'll let the forum know how it turns out. I'm sure the trick will be in syntax.
Could someone supply an image of the HV transformer block and the multiplier diode/capacitor area? Also where does the back of the HV connector go to. Is this thing a driver for a stack or an x-ray head?
Some of this stuff must be potted if in this rather smallish box!
Just curious.
Jim Kovalchick
Can anyone help me with what the ASCII and hex strings for TCP packets should look like? The manual says format looks like for example <STX><22><,><ETX>
This probably means something to coders but not to me.
Also, any guesses on what the port number would be?
Andrew Seltzman
The entire HV section is potted.
TCP_IP_spellman_DXM='192.168.1.4'; %IP address of spellman power supply
port_spellman_DXM=50001; %port to connect to supply (50001)
STX=char(2); %ASCII 0x02 Start of Text character
ETX=char(3); %ASCII 0x03 End of Text character
Ex, programming the DAC for voltage output would be 'STX,10,kV_DAC,ETX'
where kV_DAC=0-4095 = 0-100%
so the string for 10% output would be
char(2),10,410,char(3)
char(2) and char(3) are the ascii characters 0x02 and 0x03, not the character 2 and 3, all others in the string are literal character values
Andrew Seltzman
Andrew Seltzman
I successfully built an insulating dummy plug for the supply for high voltage testing and ramped both supplies up to 70kV without issue.
Andrew Seltzman
Sarvesh Sadana
Real name: Sarvesh Sadana
Post by Sarvesh Sadana »
After digging through my closet, I managed to find an old laptop that still runs XP.
I used a direct connection through ethernet, and got the applet to appear. However, I got a notification stating that it wasn't set up properly. It appears the interlock connection was open while running it remotely. I tried turning on the HV, but it immediately turned it off.
Anyone have any ideas on fixing this?
Some forward progress for this novice at network admin. Got me a crossover cable and some hints. Set laptop IP address to 192.168.1.1. From command shell in Windows 10, "ping 192.168.1.4" was successful. Browser access to http://192.168.1.4/Applet.html, from Chrome, brought some kind of No Java message.
From IE, after updating Java and adding that applet to Java's Trusted Exceptions list, I got the Spellman monitor page but could not get past the login prompt.
Enough for tonight.
PS is still running on external 24 VDC. Needs to be tried on AC with a new line-in fuse.
If that looks promising, I think the short path to HV testing (for me) is to make an analog control panel like Dan (?) talked about. Nice trick about getting +10V from one of the internal filament-limit trimpots, but I'll probably just regulate the voltage from J2 signal named +15V. How about connecting the spare pin internally to TP1, which is labeled and measured to be +10V?
Peter Schmelcher
Andrew I powered up the supply using the 24V fan idea and my supply works as expected. Low voltage test points are fine plus ethernet is good. The hobbs meter reports 225.9 hours HV On.
I think everyone should inspecting C149 33uF 450V for any signs of venting electrolyte before applying 120VAC!
The capacitor can top is a mechanical fuse that is designed to tear open under failure conditions. The top of mine bulged slightly and leaked. C149 might be the root cause of my damaged unit.
-Peter
Dan Knapp
Post by Dan Knapp »
Pin 15 is not available as a spare on the custom version of the supply. See Andrew's Nov 22 post. Pin 15 is an additional interlock input. I need to post a revision of my analog controller circuit to reflect this. It also appears that the other (other than voltage control) inputs cannot be left floating as in my circuit diagram. My DXM is not yet producing HV, but I seem to be making some progress.
Jim Kovalchick
Sarvesh,
You need to jumper the interlock pins to proceed. See Andrew's posts and the manual. Nice job getting the applet to run.
Rich Feldman,
You got to the same point I did with getting the applet to start and stall. I did the network settings the same way. I think the only way the applet will run is on an old version of JAVA.
Yesterday, I tried to use an app called Packet Sender to send commands as TCP packets to the unit. As I suspected, I really struggled with the syntax of the strings. You need to know a good portal number, and it seems that Andrew is correct that 50001 will work because I can get return strings back from that portal. My trouble is getting coherent instructions to and from the unit. The app is nice, but it want''s to translate ASCII strings into two digit hex and I'm sure that I am failing miserably at this.
After the holiday, I may try to teach myself enough Visual Basic to try that approach. ...and Kuba, no fair saying that it is the programming language of your grandfather. I don't know how old you are, but probably back before you were born I was entering machine code into an Apple one hex digit at a time because I was too poor to buy an assembler. Visual Basic is seems like a dream compared to that.
A terminated ribbon cable and PC board header are in hand for my analog control "fixture". Thanks for the reminder about pin 15.
Thanks for drawing that up, Dan. While you're editing, please consider:
1. Change -75 kV to -70 kV in two places, to match the nominal voltage of DXM70N power supplies instead of their output connectors.
2. Change DB-15 to DA-15 in three places. The letter B was mistakenly carried over from DB-25 in the real RS-232 standard. (Both are D-sub connectors.)
3. Add the Zo values (5k,5k,10k) of the three analog monitor pins. That's important for controllers that have analog or digital panel meters, easily calibrated to indicate kV and mA.
Thanks Andrew for the full testing and the full, realized output of a working one of these units. It will be great to see someone use one of these to do fusion. I am a little concerned about the ultra low current capability of the device and whether there is an "auto kill" at exactly 8ma. This was frustrating to the VCU nuclear engineering folks who spent $$$$ on a brand new rack mount 30kv 10ma spellman supply. The moment they started to do fusion, the supply tripped offline. This forced a frustrating reset and re-approach to the fusion threshold. They have now spent more $$$$ for yet another beefier supply.
Super electronic supplies by the best manufacturers seem to auto protect as they hit the honestly rated limit on current and can catch and trip on 15ma bumps and burps in the gas conduction regime. This is one of their most nasty faults and crippling limitations for the amateur fusioneer. I guess we will wait and see.
The one good thing about a home brew HV supply that is metered very well is that there is not current trip point, be the supply a home made switcher or a classic hard-nosed linear type. The human being is in total control and not some engineered safety trip point working in the micro-second or millisecond time frame to shut the entire thing down. The homebrew will take the burps and bumps and the end user will never even see the metering jiggle.
My statement in many FAQs about one absolutely having to have 10ma of current in any HV supply before lower level, detectable fusion begins was a full running, stable, 10ma. Excursions and burps and bumps of 100ma or even more are possible as the user learns to apply the voltage needed to do fusion. The gas conduction regime rules the roost and a sudden strike of the glow at 28kv in a good system can easily draw a multi-millisecond 250ma bump! Your supply can't see this and trip out or you will never get there.
Sound defeatist? It's not me, it is the physics of what we are doing.
