Over the past three days I’ve literally thrown the kitchen sink at the supply and have had no reportable performance issues. Collectively, it’s now got about two hours of run time and has incurred two 30 minute non-stop operational runs.
Tonight I decided to “destroy” the supply by running it full tilt (saturation point of the rewound MOT which supplies the driver). Well, it wouldn’t fail, just kept going and the neutron numbers just kept climbing. The maximum raw CPM/N on the Ludlum 2221 was over 23,000. Based on this fusors ability to load, I’d suspect tomorrow’s run will be in the mid 30k range.
So far the value of the multiplier caps are remaining true to their specs. But tbh, I really don’t care if one blows out at this point. Each capacitor is about 50 cents, so if I have to replace one every now and then it’s no big deal. Additionally, it’s modular design makes for a 10 minute process to replace. The performance to capacitor replacement ratio is well worth it...providing its ultimately required.
Now the real difficult stuff begins, getting the gamma spec system up and running. We built a new computer a month ago and the sound card isn’t working well with the MCA software. The ultimate goal is to activate Molybdenum and detect Technetium via the MCA, so that’s now priority.
Here’s the latest run with the flyback supply. Please excuse the clutter, I know it’s a mess:
https://youtu.be/arbNemCBjho
Custom Fusor Power Supply
- Mark Rowley
- Real name: Mark Rowley
Re: Custom Fusor Power Supply
Great work and a great supply. Nice video. You continued removal of the 3He tube from the moderator is great. All newbies need to take special notice of this wonderful proof of fusion with a thermal neutron detector as "running proof" that you are fusing. It looks like you have a super supply that is fully capable. Again, great work.
- Real name: Dennis P Brown
A really impressive feat on the PS. Good pics. Also, could you supply a schematic of your power supply?
A pic of the fusor and overall system would be nice, too.
- Mark Rowley
Thanks Dennis
The fusor hasn’t changed at all. It’s the same as listed in the original threads.
viewtopic.php?t=13503
viewtopic.php?t=13536
Regarding the schematic, I really dont have one as it’s assembly is extremely basic. On page one, you can see the basic outline of the components which almost by itself is a perfect schematic.
In a nutshell, it’s just 4 custom AC flybacks being run in parallel. The outputs are individually fed into separate single stage multipliers. The outputs of the multipliers are placed in series providing the 60kV.
As Richard correctly pointed out, the ceramic capacitors do tend to loose some value after lengthy run times. However, nothing to the point where performance was compromised, at least to a noticeable level.
Twice now, I’ve intentionally pushed this design to the point of destruction. The last failure occurred at ~89kV / 5mA. A arcover condition occurred in the #4 multiplier causing a surge that took out half the diodes. Zero damage to the flybacks, ZVS driver, or caps. The diodes were rated at 20kV (which is ok for the multiplier circuit) but the almost 90kV arcing over made the diodes easy pickins. Being that I designed this to be a 60kV supply, the failure is actually a success. A success that under harsh conditions the flybacks survived as well as the driver. Replacing the diodes only took about 30 minutes and it was good as new. I’m fairly pleased as it’s proven to be a very stable design for 60kV.
I’m currently in the process of making a couple design changes that may or may not make a difference. First, each multiplier will be changed from half wave to full wave. And secondly, I’m replacing the ceramic caps with 2nF 30kV poly/foil types. As with the ceramics, I’ll be periodically checking the values for any signs of degradation.
Once reassembled I’ll update.
