Used Flange Gaskets
Jake Wells
Real name: Jake Wells
Used Flange Gaskets
Post by Jake Wells » Mon Dec 29, 2014 1:34 am
I have a 10 porthole chamber all with 2.75 cf flanges. The knife edge of the cf flange bites down on the gasket. Could used gaskets also work? I am concerned that the indentation in the gaskets might prevent the flanges from creating a seal.
Could gaskets like these work even if they have an indentation in them?
― Nikola Tesla
Jerry Biehler
Re: Used Flange Gaskets
Post by Jerry Biehler » Mon Dec 29, 2014 2:50 am
Jake Wells wrote:I have a 10 porthole chamber all with 2.75 cf flanges. The knife edge of the cf flange bites down on the gasket. Could used gaskets also work? I am concerned that the indentation in the gaskets might prevent the flanges from creating a seal.
Nope, 1 use only. Though if you are careful you can get two uses out of them by only squishing them half way.
You can also use square section o-rings in place of the copper seals. They are reusable and are fine as long as you dont need to bake out at high temps or go to UHV levels.
Post by Richard Hull » Mon Dec 29, 2014 5:18 am
Sealing up a multi-flanged system can be a real bear, but sometimes that perfect used chamber comes our way, cheap.
If this is what you have, blow the money on a 12 pack of 2.75 gaskets. once sealed, never open or release those ports not used ever again.
2.75 gaskets are cheap enough to not bother with any attempt at re-using them.
Jake Wells
Post by Jake Wells » Mon Dec 29, 2014 6:34 pm
But i thought with tons of clamping cf flanges are very good at creating a seal?
― Nikola Tesla
Bob Reite
Real name: Bob Reite
Post by Bob Reite » Mon Dec 29, 2014 10:00 pm
I've gotten away with reusing a copper flange gasket once, by making sure that the mating part goes back on exactly the same way. The gasket itself usually sticks to one part. If the gasket comes off totally, it's nearly impossible to get it back on the same way and it will leak.
Jerry Biehler
Post by Jerry Biehler » Thu Jan 01, 2015 10:58 am
Jake Wells wrote:But i thought with tons of clamping cf flanges are very good at creating a seal?
Once you take it off there is no guarantee you have a seal anymore. You might if everything lines up just perfect but most likely you will get a leak. Its just not worth messing around with. Order a pack of gaskets from LDS Vacuum and be done with it, at $17 for a pack of 10 you just cant mess around:
http://vacuumshopper.stores.yahoo.net/234copgas.html
Jack Puntawong
Real name: Kunakorn Puntawong
Post by Jack Puntawong » Thu Jan 01, 2015 1:20 pm
It is as the other have said. One use only. However, if you aren't going into the realm beyond 10^-4 torr, you might want to consider viton gasket. They are more expensive than the copper ones but they are reusable. If you are considering on modifying your fusor again and again, like me, you might want to use them.
