How to improve your mechanical vacuum pump
HEAVY WATER
Real name: 彭译锋(peng yi feng)
Post by HEAVY WATER »
If you have a small mechanical vacuum pump.How can you improve it?
You only need a electric drill and it is very easy to get the high vacuum.LOOK AT THE PHOTOS!
A 150W mechanical vacuum pump
Open it
Open it
Link it like the photo
the higher vacuum
the higher vacuum
Isn't enough?You can put more vacuum pump oil in it vacuum pump and use the bigger electric drill.
Andrew Robinson
Real name: Andrew Robinson
Re: How to improve your mechanical vacuum pump
Post by Andrew Robinson »
I'll wait for one of Richards classic comments here :)
No witty comments needed. What is needed is a good high vacuum TC gauge, of course.
Doug Browning
Real name: Doug Browning
Post by Doug Browning »
MacGyvering tech:
Five vacuum cleaners in series should work too (reportedly each can do 20 % of 1 ATM). So put those on the outlet of the vane pump to get a 2 stage pump. Then put 283 stacked Muffin fans on the pump inlet side to fill in for the turbo.
(Pfeiffer TPU 050 runs at 90,000 RPM and has 11 rotors and 11 stators. 2 pole/60 Hz Muffin fan runs at 3500 RPM. So, 90,000/3500 * 11 => 283 ; needs CW and CCW fans alternated. )
Looks like the usual turbo might be cheaper. A lot of odd O rings needed for all those Muffin fans too. Maybe could glue them together. For throttled Fusor use, could probably get away with a factor of 10 or 20 less compression ratio though. Then only 14 computer fans (magnetic bearing type) at maybe $2 each off Epay China. Could just stuff them into a foot long 3" diameter ISO 80 pipe with some conductance limiting packing around them.
Last edited by Doug Browning on Wed Nov 05, 2014 3:30 pm, edited 3 times in total.
HEAVY WATER
Richard Hull wrote:No witty comments needed. What is needed is a good high vacuum TC gauge, of course.
I don't have a a good high vacuum TC gauge.I think that I must buy one now.
Post by Chris Bradley »
HEAVY WATER wrote:If you have a small mechanical vacuum pump.How can you improve it?
Sell it and use the money to help replace it with something bigger?
HEAVY WATER
But I don't know where can I buy the diffusion pump with a cheap price
Andrew Robinson
Peng yi feng,
I think you need to do some more reading first. Spend some time in the FAQs.
